Utility Sink Pump? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-26-2008, 06:11 PM   #1
utility sink pump?
Hey you guys,
I want to install a utility sink into my parent's basement. Only problem is, I've got no money First of all, is it possible to hook up a cheaper washing machine pump to a utility sink and have it pump up the water to the drain pipe instead of buying one of those expensive directly mounted utility sink pumps? I figured if our washing machine is pumping water up to the drain pipe then it could do it for a sink too right?
If it can't be done, do you guys know of any really cheap utility sink pumps mounted or not? Thanks
mepeterser2451 is offline   Reply With Quote
Old 11-27-2008, 12:51 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 330
Ayuh,... I'm not a Plumber, muchless a "To the Code" plumber....Although I've personally plumbed Many houses...
But,...
As a Master Re-engineer,....
I think that's a Brilliant Idea.....
All those pumps need is a Flooded Inlet to work,+ depending on just How you mount that under the sink,...
It should work just Perfectly......
Bondo is online now   Reply With Quote
Old 11-28-2008, 10:50 AM   #3
Technically, it could be done. The pipe going into the current house drainline requires a trap and a vent on it though to avoid sewer gas from entering the house.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-01-2008, 11:46 AM   #4
so i realized that we still have our old kenmore washing machine motor. All I need to do is get the pump that will work with it. My question is how do I set the pressure switch up with the sink so that it drains when the water level gets too high? Do I do it like a washing machine and hook up a vertical hose to the bottom of the sink and as the water rises the air pressure pops the piston? Or is it possible to set it up with a float switch? It seems like that would be easier. Any other ideas?
utility sink pump furiousstyles Plumbing 4 11-06-2009 04:52 PM
Installing a utility sink BNPadgett Plumbing 1 05-03-2008 10:49 AM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 10:11 PM
utility sink, washer drain simon Plumbing 4 11-14-2007 08:30 PM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 03:30 PM
