Utility Sink With Pictures! - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-10-2011, 12:54 AM   #1
Utility Sink with pictures!
Go easy on me, this is my first plumbing project.
My house is a tri-level, and both bathrooms are on the top floor. The laundry room is on the lowest floor (garage level) and i am going to add a utility sink in the garage. The plumbing for the laundry is inside the wall opposite where the sink will go, so this should not be very difficult.
My first question is regarding this pic: This will be the drain for the sink. It will drop into the 3" horizontal main that slopes to the street.
Utility Sink with pictures!-house-plumbing-5-9-2011-005.jpg   Utility Sink with pictures!-house-plumbing-5-9-2011-009.jpg
Bloke is offline   Reply With Quote
Old 05-10-2011, 06:15 AM   #2
And your question is????????????
Don't forget the vent connection.
Old 05-10-2011, 09:10 AM   #3
I actually have 3 initial questions:
The 3" horizontal pipe is the "stink pipe" and it takes waste from the upstairs 2 toilets. The point where i would like to cut in and have the drain for the new utility sink is just a few inches downhill and so close to the toilet junctions.
As it is my first time cutting into the 3" pipe (1) i want to be sure this location looks ok, and (2) with a vent going above the utility sink, i will not have sewage comping up into the new fixture. And (3) what can i expect when i start cutting into the 3" pipe? What is best saw for this?
Old 05-10-2011, 09:24 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Location is fine.
Do you have a sawzall? I like a sawzall with a bi-metal blade, it makes a cleaner cut than a regular wood blade, but you still need to deburr the pipe before gluing. If not any kind of handsaw you have will work. Hacksaw is a little too fine of teeth. Need something coarser than that.
There shouldn't be anything really nasty in that pipe. It looks like it has nice grade. If there is, then you have discovered a problem.
My question : How are you going to get that fitting on there? You have to have some flexibility in the pipe. If you don't have enough, you might have to get a no-hub coupling to make it work.
You could eliminate a fitting there as well if you used a wye instead of a combo, and use one of your 1/8 bends to change to vertical. It's not illegal the way you're doing it, but a bit more expensive.
Journeyman Plumber
Old 05-10-2011, 11:38 AM   #5
Originally Posted by Alan View Post
Location is fine.
Do you have a sawzall? I like a sawzall with a bi-metal blade.
Thanks for the reply!
I will have to get a sawzall, and just manually saw away. I really like the cutoff blade i have in my circular saw for the 1.5" tubes. Too bad i can't use it on the 3".
You asked How am i going to get he fitting on there? Well, if i cut the 3" pipe in the right place, everything appears to line-up. If i did a no-hub coupling, i think it would be best to go with a 1.5" no-hub, and not the 3" ??
Old 05-10-2011, 11:43 AM   #6
Household Handyman
Rewards Points: 1,408
Unless you will have further need of a Saw-Zall, that's a lot of money spent for just a few cuts on this pipe. They do sell a sort of "hand-saw" for PVC piping, a thin, round blade with handles on both ends. This does work rather well and especially in tight spaces. Actually I've seen one plumber cut 4" PVC with a piece of nylon cord from his plumb bob, using two screwdrivers as handles.
Old 05-10-2011, 12:15 PM   #7
Rewards Points: 256
My saw of choice for pvc is a japanese pull-cut saw. Cuts fast, accurate, smooth finish: will still need to de-burr.
michaelcherr is offline   Reply With Quote
Old 05-10-2011, 12:21 PM   #8
I've got a half-bath to install too! So i could probably use a sawzall on several other cuts too.
I practiced with a standard hack-saw on 1.5" PVC, and the cut was never straight. It kept walking at an angle, even when i was trying to go slow and follow a line. I think the blase is just to thin and flexible. I think the cut would never be straight on a 3" pvc with the hacksaw.
Old 05-10-2011, 04:48 PM   #9
OK, since there seem to be no problems with my plumbing, I will be cutting it in and glueing tonight. I will then take some final pics.
Old 05-11-2011, 12:51 AM   #10
Alan! I have everything ready to begin cutting the long horizontal 3" pipe. Before cutting, i run through it in my head again. And your comment finally hits me. How much movement can i get out of the big drain pipe, once it's cut, to slip the reducing wye in?
I can remove enough of the hanging support straps to allow movement, but this raises two questions:
1) how much flex in 3" pvc is there in a 10' span? I just need 2 to 3 inches of opposing movement.
2) what is weakest link if i try to flex the pipe too much? a fitting at the end, where it is glued, probably.
So, now as a DIYer, I don't feel very confident about cutting into my house plumbing. I have no idea how much i can move the pipe until i have it cut. Maybe the thing to do is have a coupler ready in-case i can't get the movement and just stop work for the day.
Old 05-11-2011, 04:22 PM   #11
Anyone cut into a 3" pipe like this, and find out you don't have enough horizontal movement to slip in a Y ? (see my post above for more description).
Old 05-12-2011, 07:10 AM   #12
biggles's Avatar
how about just going into that 1 1/2 line with a t-y from the washing machine the chances of using both at the same time are going to be rare...and that dumping of the washer cycle will keep the line clear of stuff done in the slop sink...just trap up the sink still have the receit for that main t-y in hand
Old 05-12-2011, 11:54 PM   #13
Doing it myself
Alan's Avatar
There you have it! Yes, grab a No-Hub coupling and just plan on using it. It will save you 20 minutes of fight and frustration. You probably won't get enough flex out of PVC. ABS is a bit more forgiving, but I'd normally still use a No-Hub on ABS.
You need a minimum of 1" sticking out of the fitting for the No-Hub to attach to. Glue your piece into your new fitting, take a measurement, make the cut, put the no-hub on the existing piping, slide the band off the rubber part, further down the existing piping, FOLD THE RUBBER BACK onto itself, Glue, level, fold no-hub back down, tighten the band. Finish plumbing the rest.
Journeyman Plumber
Old 05-13-2011, 12:01 AM   #14
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I have found that a lot of time rather than separating the cut pipe longitudinally, I lift one of the cut ends and push down on the other, or move them side to side (each one opposite from the other). The side to side often works better. Move them far enough so the opening gains enough length to be able to put the fitting in there at an angle and then push the two cut pipes back into line with each other which shoves them into the fitting at the same time.
Old 05-13-2011, 12:35 AM   #15
Well, i decided to go for it... and there was just enough movement in the main tube to allow the combo T to fit.
Here are the completed pics (minus putting the wall back together with screws and spackling). I am also thinking about a plastic back splash to cover the wall area.
Utility Sink with pictures!-house-plumbing-5-11-2011-pic-003.jpg   Utility Sink with pictures!-house-plumbing-5-11-2011-pic-009.jpg   Utility Sink with pictures!-house-plumbing-5-11-2011-pic-011.jpg   Utility Sink with pictures!-house-plumbing-5-11-2011-pic-012.jpg   Utility Sink with pictures!-house-plumbing-5-11-2011-pic-016.jpg
utility sink thadbuff Plumbing 1 12-30-2010 09:12 AM
Venting a sink pump WillK Plumbing 2 12-26-2010 01:21 PM
Washer drain pipe and adding a utility sink lubyone1 Plumbing 5 07-09-2010 10:56 PM
utility sink pump installation rcassidy Plumbing 1 02-17-2009 09:34 PM
basement utility sink install bjkPoker Plumbing 2 03-18-2008 07:12 AM
