Utility Sink Drain Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-06-2010, 12:35 PM   #1
I am adding a utility sink in my basement and need to use a pump as the drain is over 4' above the floor. I am considering one like the Hartell LTA-1.
My question is, should the outlet be hard piped to the waste line (adding a new vent bypass) or can it be discharged into a 'Y' fitting similar to a washing machine discharge? If both are acceptable, is either one a preferred or superior approach?
Thanks much.
gellswor is offline   Reply With Quote
Old 11-06-2010, 06:08 PM   #2
Rewards Points: 150
You want to hard pipe it to your drain line, you should pipe up until you are just above your drain line and and grade it to the line ( don't pump up any farther then you have to). If you plan to discharge a wash machine into your sink make sure you read specs. about that.
braindead is offline   Reply With Quote
Old 11-06-2010, 08:14 PM   #3
Ok thanks for the info, I'll do that braindead.
Old 11-07-2010, 07:34 AM   #4
I have a followup question.
My house (1986) has two 3" plumbing vents. One vertical that goes out the roof, and a second horizontal, in the basement just before the grease trap.
Questions:
1. What is the purpose of the second vent?
2. Can I use this horizontal vent to vent the new utility sink that I am adding in the basement?
Again, thanks for your help.
Repair Utility Sink in Basement lincolnparkjok Plumbing 5 08-04-2014 06:04 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
sink drain makes gurging sound ninghai Plumbing 1 08-04-2010 02:30 PM
Washer drain pipe and adding a utility sink lubyone1 Plumbing 5 07-09-2010 10:56 PM
Reversing P-trap in bathroom sink drain? DK75 Plumbing 3 03-02-2010 01:30 PM
