-   -   Utility Sink Drain Pump (http://www.diychatroom.com/f7/utility-sink-drain-pump-85959/)
gellswor 11-06-2010 12:35 PM
I am adding a utility sink in my basement and need to use a pump as the drain is over 4' above the floor. I am considering one like the Hartell LTA-1.
My question is, should the outlet be hard piped to the waste line (adding a new vent bypass) or can it be discharged into a 'Y' fitting similar to a washing machine discharge? If both are acceptable, is either one a preferred or superior approach?
Thanks much.
braindead 11-06-2010 06:08 PM
You want to hard pipe it to your drain line, you should pipe up until you are just above your drain line and and grade it to the line ( don't pump up any farther then you have to). If you plan to discharge a wash machine into your sink make sure you read specs. about that. :)
gellswor 11-06-2010 08:14 PM
Ok thanks for the info, I'll do that braindead.
gellswor 11-07-2010 07:34 AM
I have a followup question.
My house (1986) has two 3" plumbing vents. One vertical that goes out the roof, and a second horizontal, in the basement just before the grease trap.
Questions:
1. What is the purpose of the second vent?
2. Can I use this horizontal vent to vent the new utility sink that I am adding in the basement?
Again, thanks for your help.
