Utility Sink Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-18-2011, 11:50 PM   #1
Just call me Andrew
Rewards Points: 1,020
Utility sink drain
I have a project coming up to install a utility sink in my parents' basement. It's pretty straightforward, aside from cutting in the drain. I'll be using an AAV for venting.
Would it be OK to use the cleanout on the right side of the pic below as the feed for the new drain? (The pic below is not of my parents' house, it's from another thread but a very similar setup).
The situation in my parents' house makes it VERY difficult to cut into the 3" PVC, but they do have a cleanout. Could I get a 3x3x1.5" tee, and connect it to the existing female threads (which used to have the cleanout plug) with a 3" male fitting adapter? The other 3" of the tee would have a new cleanout, and the 1.5" would be for the sink.
Andrew
secutanudu is offline   Reply With Quote
Old 05-19-2011, 09:06 AM   #2
Absolutely, not a problem.
VIPlumber is offline   Reply With Quote
Old 05-19-2011, 09:13 AM   #3
Just call me Andrew
Awesome, thanks. What's the best way to position the tee? Should the sink come in from the bottom or a side?
Also, is it better to extend some 3" pipe a couple feet before putting in the tee to get it away from the toilet coming in above?
Andrew
Old 05-19-2011, 09:50 AM   #4
I'm not sure I understand. The drain should always be positioned at the proper grade, in this case 2% (or 1/4 per ft).
Good idea, although not completely necessary.
Old 05-19-2011, 10:08 AM   #5
Just call me Andrew
Well the utility sink will use a pump since the drains piping leaves the house above the sink. So do I go up from the sink and have the tee pointing down?
Or do I have the tee pointing sideways (slightly upwards) and have the sink go "up and over" to get into the tee?
Kind of hard to explain...hopefully you understand what i mean.
Andrew
Old 05-19-2011, 10:47 AM   #6
Just call me Andrew
I guess if the tee is pointing down, that could lead to waste in the pipe dropping down towards the pump....so I guess having it go up and over (with the "over" part pitched properly") towards the tee makes more sense.
Andrew
Old 05-19-2011, 10:54 AM   #7
Ahhhh, now it's clear. The T should be on it's side, raised upwards. And don't forget to install a check valve in-line, just in case.
The Following User Says Thank You to VIPlumber For This Useful Post:
secutanudu (05-19-2011)
How to add Utility Sink and Washer Drain to existing 4" obriendigital Plumbing 9 03-26-2011 06:39 PM
Reversing P-trap in bathroom sink drain? DK75 Plumbing 3 03-02-2010 01:30 PM
Drain placement for sink simonb Plumbing 3 09-08-2007 01:08 PM
installing vessel sink drain?! (HELP!) tara Plumbing 2 11-10-2006 12:17 AM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 02:30 PM
