Utility Sink Double Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-19-2013, 09:21 PM   #1
Utility Sink double Drain
Hello Everyone, the utility sink in my basement looks like its will start to leak some day soon. There is an attachment to the drain system that I have never seen before. Does any know the what the drain attachment in the picture is ? Can I remove and replace it with separate sink drains ?
grady21 is offline   Reply With Quote
Old 08-19-2013, 09:24 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 450
Sorry, but the picture isn't working
Old 08-19-2013, 09:47 PM   #3
Added photos
Hopefully the photos are attached.
Utility Sink double Drain-20130817_134742.jpg   Utility Sink double Drain-20130818_211451.jpg   Utility Sink double Drain-20130817_083113.jpg
Old 08-19-2013, 10:04 PM   #4
Rewards Points: 218
Wow. I never seen an attachment like that either, you may be able to replace it with seperate drains when it leaks if you can figure out how to remove the whole thing without breaking the sink. I don't know. I'm sure someone has seen it before and can give you some suggestions. Nice pics.
jmon is offline   Reply With Quote
Old 08-19-2013, 10:25 PM   #5
You cant repipe them seperatley,Wd40 the nut ad to not break it when removing or damaging the sink. Then either cut the old trap out and leave enough of the trap arm to put a fernco coupling on and repipe with tubular pvc. Also you can try to unthread the trap arm nipple and repipe from there..
Peppe1019 is offline   Reply With Quote
The Following 2 Users Say Thank You to Peppe1019 For This Useful Post:
grady21 (08-20-2013), jmon (08-20-2013)
Old 08-21-2013, 10:05 PM   #6
Master Plumber
Javiles's Avatar
Rewards Points: 990
Looks like something for the plumbers museum. looks ok from the slip nut up the tail piece trap and waste arm need TLC.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following 3 Users Say Thank You to Javiles For This Useful Post:
jmon (08-21-2013), oh'mike (08-21-2013), VIPlumber (08-22-2013)
Island sink drain problem oldphoneman Plumbing 2 02-06-2012 11:56 PM
Utility sink drain secutanudu Plumbing 6 05-19-2011 11:54 AM
Sink drain leaking, question bergerdude Plumbing 3 03-27-2011 01:43 PM
Utility Sink Drain Install (I've Searched!!!) sturg11 Plumbing 10 03-13-2009 02:13 PM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 03:30 PM
