Using Thinset To Level A Rocking Toilet? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-03-2008, 01:32 AM   #1
Using thinset to level a rocking toilet?
I've got a toilet that sits on a slightly uneven floor. I was thinking about putting some thinset down before dropping the toilet in place. Anything wrong with this method of leveling off the toilet? Any suggestions? Thanks.
digexpressions is offline   Reply With Quote
Old 05-03-2008, 08:39 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
There are beveled plastic shims made for the pupose that would be much easier and better to use to level the toilet. Put a level across the bowl to get an accurate level setting for the toilet. Use mildew resistant tub-and-tile caulk around the sides and front of the toilet base to hide the shims and gap, but leave the back open for any future leak detection.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 05-03-2008, 08:42 AM   #3
Plumbing Contractor
It certainly would be unconventional fix... Not that it won't work...just unconventional!!
Hey, depending on just how out of level the floor is...they make PLASTIC SHIMS for this situation (can be stacked if necessary)....usually found at home supply stores OR at a local plumbing supply house. Then you can run a bead of silicone around base to hide/fill space around base.
Although not ideal, this works very well. Just be sure to use a reinforced wax gasket (has neoprene inside the wax) when setting the toilet.
Let me know what you think.
Boston Plumber is offline   Reply With Quote
Old 05-03-2008, 08:43 AM   #4
Plumbing Contractor
Hi again, Mike....looks like we were writing at the same time again...
Good advice!!
Old 05-03-2008, 05:57 PM   #5
Pro friend of mine uses tile grout....says it will break away if you ever remove toilet some day.......but only if floor is really out of level like greater thatn 1/4"......I just pulled a "rocker" and will use plastic shims.
Mike S is right on with leaving the back open so you can detect any leaks in future.
jbhandyman is offline   Reply With Quote
Old 05-03-2008, 08:24 PM   #6
Send a message via AIM to Marlin
It's not unconventional at all. I use plaster of paris, put in hundred of bowls that way.
Marlin is offline   Reply With Quote
Old 05-03-2008, 08:46 PM   #7
Long-Time DIYer
I'm not a pro plumber. That's just how I set a toilet.
Everything I "know" about plumbing, I learned from pros.
Great minds think alike. LOL
Mike
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
toilet bowl water level problem? darsunt Plumbing 3 08-26-2007 02:10 AM
Water level in toilet bowl Kath Plumbing 10 06-22-2006 04:26 PM
