Using Sharkbite To Fit Leak In Pipe...pipe Hole Size Question. - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-06-2009, 03:50 PM   #1
Rewards Points: 384
Using sharkbite to fit leak in pipe...pipe hole size question.
So while putting up drywall this weekend my buddy put a drywall screw right through the main copper water line. Luckily I had one of those clamp style patches to hold it for now and I had a plumber come look at it on monday. $150 to fix it. Man, I know plumbers have it made in massachusetts but seriously, what is this a 10 minute job at that? I respect what they do but every bone in my body says that's just ridiculous so I'm going to patch it myself.
I was at lowes and they tried to convince me to use a pressure fitting but I've heard great things about the sharkbites so I think I'm going to go that route. The part is around $6 but there are no instructions and I can't find anything online about how much pipe to remove in order to fit the fitting between the ends. Any though on this?
RyanD is offline   Reply With Quote
Old 08-06-2009, 05:21 PM   #2
Registered User
Termite's Avatar
Sharkbite has great installation instructions on their website last time I looked.
Old 08-06-2009, 05:24 PM   #3
Rewards Points: 384
Just on how to hook it up to a new pipe..not to an existing one mid-run.
Old 08-06-2009, 08:51 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
If Your pipe is connected at both ends (and I assume it is) you will play hell trying to get that Sharkbite installed (no way to move the pipe. I would cut the pipe at the screw hole, clean & flux, install a repair coupling and solder it. A repair coupling has no stop in the center so you can slide it fully over the end of a pipe. May not find at a big box but any plumbing house will have them.
rjniles is offline   Reply With Quote
Old 08-14-2009, 07:17 PM   #5
We pick these?
I had to repair a repair, of a similarly punctured 5/8" water line that had been soldered a few years back and was leaking. I used the sharkbite slip union and a regular sharkbite union with a section of copper pipe. The slip is somewhere around 2-1/2" to 3". It's able to be used on copper tubing as there is no way to get a stiffener into PEX.
NailedIt is offline   Reply With Quote
Wire size for distance Question fburke Electrical 4 07-28-2007 10:29 AM
Vent stack leak and install question bjstewa Plumbing 5 06-09-2007 10:01 PM
pipe leak & sheetrock damage santogr General DIY Discussions 2 03-04-2007 02:44 PM
grounding to water pipe question eastvantrading Electrical 6 12-20-2006 10:49 AM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
