-   -   Using sharkbite to fit leak in pipe...pipe hole size question. (http://www.diychatroom.com/f7/using-sharkbite-fit-leak-pipe-pipe-hole-size-question-50378/)
RyanD 08-06-2009 02:50 PM
So while putting up drywall this weekend my buddy put a drywall screw right through the main copper water line. :furious: Luckily I had one of those clamp style patches to hold it for now and I had a plumber come look at it on monday. $150 to fix it. :huh::jester::eek: Man, I know plumbers have it made in massachusetts but seriously, what is this a 10 minute job at that? I respect what they do but every bone in my body says that's just ridiculous so I'm going to patch it myself.
I was at lowes and they tried to convince me to use a pressure fitting but I've heard great things about the sharkbites so I think I'm going to go that route. The part is around $6 but there are no instructions and I can't find anything online about how much pipe to remove in order to fit the fitting between the ends. Any though on this?
Termite 08-06-2009 04:21 PM
Sharkbite has great installation instructions on their website last time I looked.
RyanD 08-06-2009 04:24 PM
Just on how to hook it up to a new pipe..not to an existing one mid-run.
rjniles 08-06-2009 07:51 PM
If Your pipe is connected at both ends (and I assume it is) you will play hell trying to get that Sharkbite installed (no way to move the pipe. I would cut the pipe at the screw hole, clean & flux, install a repair coupling and solder it. A repair coupling has no stop in the center so you can slide it fully over the end of a pipe. May not find at a big box but any plumbing house will have them.
NailedIt 08-14-2009 06:17 PM
I had to repair a repair, of a similarly punctured 5/8" water line that had been soldered a few years back and was leaking. I used the sharkbite slip union and a regular sharkbite union with a section of copper pipe. The slip is somewhere around 2-1/2" to 3". It's able to be used on copper tubing as there is no way to get a stiffener into PEX.
