Old 05-10-2011, 04:19 PM   #1
Question
using section of pipe for both drain and vent
my powder room will be right below my bathroom on the floor above. there is a vent pipe coming into the bathroom from the roof and i was gonna tie into it to discharge the bathroom sink and bath tub. then i was gonna use the same pipe for the powder room sink to get vent and also discharge. so the portion from the roof to the bathroom would be vent only but from there to the powder room sink it would perform both vent (for the powder room) and discharge (for the bathroom above). below it would be no more ties into only flow into the main in the basement below. i was wondering if this dual use for both vent and drain in that portion is OK. if it is a problem, i can run double pipe in the portion so that the vent and drain don't mix but obviously, the former design would be simpler.
thanks
Old 05-10-2011, 05:06 PM   #2
A "Handy Husband"
rjniles's Avatar
No it is not code compliant, what you are describing is a wet vent. The vent for the powder room should be piped above the discharge drain of the bathroom and can then be tied back into the vent before it goes through the roof.
Coastal South Carolina
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
amakarevic (05-10-2011)
Old 05-10-2011, 05:10 PM   #3
I've seen wet vents done before, are they not code compliant everywhere? Can you wet vent a toilet?
Bloke is offline   Reply With Quote
Old 05-10-2011, 06:07 PM   #4
Exclamation
thanks a bunch !! it shall be no problem to do it that way, just a little more pipes and joints.
Old 05-10-2011, 07:44 PM   #5
call me E
TheEplumber's Avatar
Wet vents are allowed often. You just have to meet certain code criteria. A couple of examples for my area would be:
vertical wet vent only
2" min. pipe size
fixtures must be on the same floor and no more then 6ft apart
I'm sure the IPC reads differently as will a Canadian code.
Its best to consult your local inspector.
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 05-10-2011, 07:57 PM   #6
A "Handy Husband"
rjniles's Avatar
The OP described venting the lower floor powder room into the drain of the bath above, this is a no, no. Yes wet vwenting is allowed with restrictions but I was answerimng the OP's specific case.
Old 05-11-2011, 01:20 AM   #7
Got it, no wet-venting to a fixture that is a floor above the one you want to add.
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 07:52 PM
Need to close off or move a vent pipe & drain that goes to nothing mystic_cobra Plumbing 2 04-18-2011 09:14 PM
Adding washer to basement with no way to vent drain pipe General Plumbing 6 12-26-2010 12:11 PM
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
sewer backup and stench jayhill Plumbing 12 08-14-2008 12:06 AM
