Old 04-27-2010, 04:01 PM   #1
Using schedule 40 black pipe
I'm replacing the old bathtub/shower valve assembly and I have some schedule 40 black pipe that I can use for the bathtub spout. Are there any issues with corrosion or rust over time with schedule 40 black pipe? The bathtub spout is rarely used in my house.
spaceman spif is offline   Reply With Quote
Old 04-27-2010, 05:00 PM   #2
Don't do it. you will get rust stains and the pipe will rot out very quick.
SuperPlumberGuy is offline   Reply With Quote
Old 04-27-2010, 05:23 PM   #3
My new Delta 17 series tub spout calls for either 1/2 inch copper or iron pipe for the drop and the spout nipple. Are you saying that if I use it, it will rust out prematurely? I don't understand why they would reccommend something that is so prone to failure. In the meantime, I am not experienced at sweating copper pipes and was really trying to avoid doing that on this expensive faucett. How do you know if it's schedule 40 iron pipe and is there a better quality iron pipe for this?
Jim F is offline   Reply With Quote
Old 04-27-2010, 06:00 PM   #4
Jim F....I have seen that in the directions myself and it is very misleading. What it should say is to use a material that is iron pipe size (IPS) which basically means schedule 40 threaded pipe. If you do not wish to solder at the very very least use galvanized pipe,but, I would STRONGLY recommend using brass. 1/2" IPS brass nipples and fittings are readily available at any hardware or big box store. DO NOT use standard black iron.
The Following User Says Thank You to SuperPlumberGuy For This Useful Post:
Jim F (04-27-2010)
Old 04-27-2010, 06:21 PM   #5
I'll go with brass! Thanks!
Old 04-27-2010, 06:37 PM   #6
Yep, me too. Not the first or the last time I bought the wrong stuff. Fortunately, it's not all together yet.
Gas Pipe General Questions jamiedolan Plumbing 10 12-06-2012 11:46 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Splicing ABS Black Vent Pipe Garfield Plumbing 1 12-07-2009 03:53 PM
running black gas pipe lukeg Plumbing 6 10-25-2009 12:16 AM
Identifying size of Black Iron Pipe jamiedolan Plumbing 2 10-06-2008 01:39 AM
