Using Rubber Couplings On Drain Lines. - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-23-2011, 02:08 PM   #1
Using rubber couplings on drain lines.
I cut into a copper drain line to add a Y to connect a dishwasher. I used PVC and joined them with two rubber couplings. Now I'm selling the house and a home inspector told the new buyers that I needed to remove the rubber and have it "plumbed properly". Is using rubber couplings not OK or against code? I live in a small town outside of St. Louis, Mo. Hopefully someone will give me some facts I can give to the prospective buyers.
Mike.
lake tish is offline   Reply With Quote
Old 08-23-2011, 02:27 PM   #2
fabrk8r
fabrk8r's Avatar
You could remove the rubber coupling and glue a 75 PVC coupling in it's place in a few minutes.
Then it will meet code.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-23-2011, 02:44 PM   #3
Going from copper to PVC? The copper has an outside diameter of around 1 3/4" and the the PVC is 2" OD.
Mike
Old 08-23-2011, 02:47 PM   #4
Here is what it looks like.
Mike
Old 08-23-2011, 02:56 PM   #5
fabrk8r
fabrk8r's Avatar
Ah, sorry, didn't see the part about copper to PVC.
Hopefully a plumber will chime in with the correct answer.
Old 08-23-2011, 03:26 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 566
Areas vary. But a shielded coupling (no-hub) should work.
Old 08-23-2011, 11:15 PM   #7
A shielded coupling looks like this.
VIPlumber is offline   Reply With Quote
Old 08-24-2011, 07:38 AM   #8
Plumb or Die!
What is that copper pipe draining? A dishwasher has to be trapped, that's why they're usually connected to a sinks trap arm. If that line is a trap arm, cut out the whole mess and using an 1 1/2" copper to PVC transition coupling like the other guys talked about, repipe the sink. If it's not on a trap arm, you'll have to post more pics and we can figure out a way to trap the dishwasher, and vent it.
plumber666 is offline   Reply With Quote
Old 08-24-2011, 08:03 AM   #9
why wasn't it hooked in to the drain under the kitchen sink or the disposal if you have one?
Sink drain leaking, question bergerdude Plumbing 3 03-27-2011 12:43 PM
Heat pump water heater drain lines sparky472 Plumbing 3 03-17-2011 03:37 PM
Septic Tank not flowing into leach lines or drain field michaelschier Plumbing 19 09-01-2010 07:58 AM
Frozen Garage Floor Drain Dragon General DIY Discussions 8 01-25-2009 06:07 AM
I am doing the happy dance..I Finally got the tub drain cleared, whew!!! Woodpecker Plumbing 20 06-09-2007 11:20 AM
