Using A Rubber Coupling Instead Of PVC Coupling - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-04-2011, 09:49 AM   #1
Rewards Points: 103
Using a rubber coupling instead of PVC coupling
Hello,
I am in the middle of doing a major bathroom remodel. I am replacing everything including floor, walls, bathtub, shower, pluming, etc.
I assembled and attached to a tub a waste& overflow drain unit and need connect it to a drain pipe. I need connect two 1-1/2 PVC pipes to make a straight line. Normally I would use a 1-1/2 PVC coupling and PVC glue. However, due to some limitations I cannot pull pipes out to insert and glue a PVC coupling, so I am thinking about using a 1-1/2" Rubber Coupling. I used it once 5 years ago to connect PVC pipes under one of my sinks and it still fine.
But this connection will be located underneath of my second floor bathtub and it won't be accessible from the second floor after I finish my project. So, I am a little concern about reliability of rubber couplings.
Any opinion and experience with rubber couplings would help a lot.
Thanks.
sukhenkoi is offline   Reply With Quote
Old 04-04-2011, 10:09 AM   #2
Owner
LateralConcepts's Avatar
Just use a repair coupling. It doesn't have the little stop rib inside, so you just work fast. Primer, glue, slide it all the way on, then half-way back.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 04-05-2011, 06:53 AM   #3
Rewards Points: 103
I never saw repair couplings. I buy all plumbing supplies at Home Depot and Home Depot does not sell them. This time somehow I found a way to use a regular PVC 1-1/2 coupling, but next time I'll try to find and use a repair coupling.
Thanks a lot.
Leak at rubber coupling in stack WillK Plumbing 7 03-14-2011 01:37 PM
rubber hoses - code compliant? daixloxbmw Plumbing 10 01-07-2011 08:15 AM
Rubber Roof Sealant ninghai Roofing/Siding 17 03-08-2010 08:58 PM
rubber coating for paved backyard hellomoto Landscaping & Lawn Care 3 10-18-2009 10:09 AM
Rubber roof prices tgf40 Roofing/Siding 4 05-27-2008 01:02 PM
