Using Roughed In Drain - On The Right Track? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-21-2012, 01:44 PM   #1
Rewards Points: 518
Using roughed in drain - on the right track?
My builder roughed this drain in during construction and now I want to use it for a sink. I just want to make sure I'm on the right track:
- Cut the 1 1/2" DWV piece mounted horizontally with the orange cap a few inches
- install an elbow
- Strap the entire assembly so that the horizontal pipe is angled towards the floor(it sits level right now?) Is this necessary?
Connect P trap like usual.
Anything wrong with my plan?
n0c7 is offline   Reply With Quote
Old 01-21-2012, 01:52 PM   #2
Rewards Points: 518
double post
Old 01-21-2012, 01:54 PM   #3
Jack of all trades
danrb007's Avatar
Send a message via Yahoo to danrb007
Not sure i understand you plan. What I would do is cut the horizontal pipe install a 90 degree elbow staying horizontal. install p trap in elbow. depending on what type of sink you are installing will dictate what kind of coupler you need attached to the elbow.
danrb007 is offline   Reply With Quote
Old 01-21-2012, 02:03 PM   #4
Rewards Points: 518
I redid my post I didn't understand it either. Might make more sense now.
Does the pipe need to be sloped?
Old 01-21-2012, 02:07 PM   #5
Jack of all trades
danrb007's Avatar
It needs to slope at least 1/4" per foot towards the stack. Check it with a level if a plumber installed it it may already have the right slope. It can slope more but 1/4" is the minimum. Sounds like you are on the right track. is this a utility sink or bathroom vanity that you are installing?
Old 01-21-2012, 02:09 PM   #6
Rewards Points: 518
Sounds good on the 1/4". I checked it with a level and it's perfectly level so I'll have to do some strapping. It's a salon sink that's going in.
Old 01-21-2012, 02:32 PM   #7
Jack of all trades
danrb007's Avatar
in my experience (and I am not a plumber just a jack) you should be able to strap it and obtain the appropriate slope. Good Luck.
Old 01-21-2012, 02:48 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 350
If you can, get the rough in info for your sink first. You can raise/lower that tee to match. Maintain 1/4"/ft grade on the pipe.
Old 01-21-2012, 07:54 PM   #9
Rewards Points: 518
Thanks guys. Just tested and it's working fine.
Moving roughed in shower drain? NEW-B Plumbing 5 04-07-2011 10:05 AM
Sink drain leaking, question bergerdude Plumbing 3 03-27-2011 01:43 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 09:36 PM
LED track lighting feasible yet? GFW Electrical 8 01-22-2009 01:13 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
