Old 05-26-2007, 12:58 AM   #1
Question
Using a pipe threading machine (with 2" pipes)
i live in washington, dc where tradesmen apparently make more money than lawyers and doctors, at least according to their estimates.
i need to reposition some radiator 2" pipes and am looking into doing it myself as i refuse to be robbed (one guy asked me for $1,800 for one day of work !!!).
was wondering what i should know about using a pipe threader that i can rent from a plumbing supply store ? is it within the DIY domain ?
HD can also do the threading for me but i absolutely hate the idea of having to bring them accurate measurements (i HATE precise measuring - rough is okay) and having to buy and carry a new pipe if i made a mistake. i like having the tool/control and the flexibility of trial/error.
thanks,
- a
Old 05-26-2007, 02:23 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
You can get manual pipe threading tools or a machine. Go with a machine and 2" dies, and simply have them check you out on the sequence.
It isn't that difficult, and a DIYer can do it.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 08:22 AM
Threading black iron pipe? sandyman720 Plumbing 3 03-12-2007 07:50 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 04:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
