Using A Pipe Hub Donut To Join 3" PVC To 4" Cast Iron Pipe. - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-24-2010, 08:05 PM   #1
Using a pipe hub donut to join 3" PVC to 4" Cast iron pipe.
I tried using a 4"x3" half pipe donut to join a 4" cast iron pipe and a 3" PVC but its too big. Then I tried using 3"x3" and that one fits good but not really snug. Is there a good epoxy I could use or an alternative you recommend? FYI: I don't have an option to change the cast iron pipe since its embeded in concrete which I can not break.
pazmocars is offline   Reply With Quote
Old 12-24-2010, 08:37 PM   #2
Look for a 3" SV gasket. You will have to bevel the outer edge of the pvc. You will need liquid soap to soap the pipe and gasket. Assuming you have already removed the lead and oakum from the cast iron hub.
Work4living is offline   Reply With Quote
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
floor drain / cast iron to pvc? n2learning Plumbing 3 08-01-2010 06:20 PM
rubber gasket donut for cast iron sewer pipe to pvc jbitt Plumbing 6 04-25-2010 12:29 PM
Help with Cast Iron Material Tester Plumbing 2 10-25-2007 10:58 AM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 08:20 PM
