Using Old Copper Pipe?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2011, 10:29 PM   #1
Super Master Painter
Ole34's Avatar
using old copper pipe??
im no plumber but i can do basic repairs........im also a cheap mofo so my question to you is can you use old copper pipe thats been sitting around for a while??? .................i have some lengths of pipe that were never used but theyre all green and nasty looking inside, should i just toss them and buy new
Thanks in advance,
Ole34 is offline   Reply With Quote
Old 02-02-2011, 10:57 PM   #2
Experienced
Jackofall1's Avatar
If used for an outdoor hose bid, go ahead, but I think you know the answer if you were to use it for potable water.
Old 02-02-2011, 10:58 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 904
Copper is paying pretty good at the recycle centers. prolly more then you originally paid for it. Cash it in and buy some new pipe
The Following User Says Thank You to TheEplumber For This Useful Post:
LateralConcepts (02-03-2011)
Old 02-02-2011, 11:00 PM   #4
Ole34's Avatar
even if its only been sitting around for about a year and a half??? maybe nasty was the wrong word but its deff green lookin.........
Old 02-03-2011, 06:38 AM   #5
Run a shotgun brush down it, thoroughly clean the tarnish for solder connections, and use it. If it not thin wall tubing.
Old 02-03-2011, 07:00 AM   #6
Rewards Points: 1,216
Go for it just disinfect it before using it run some chloride solution through it to kill any germs. If it' s type M it's not worth it however of it's K or L definitely.
COLDIRON is offline   Reply With Quote
Heat safety during copper pipe soldering? darsunt Plumbing 9 08-13-2011 11:48 PM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 09:49 PM
Sweating copper pipe - what was I doing wrong Fortitude Plumbing 26 09-15-2010 09:12 PM
Connect 2" pvc drain to 2" copper pipe - no subfloor access missfixer General DIY Discussions 3 09-05-2009 05:44 PM
Copper galvanized pipe corrosion bluefitness Plumbing 2 07-10-2009 10:02 AM
