Using The Existing Shower Drain For New Tub. - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-12-2012, 02:17 AM   #1
Using the existing shower drain for new tub.
Hello everyone, I'm looking for advice on my bath rebuild. I am installing an MTI drop in bathtub where my shower used to be, my question is can I run a drain pipe from the bath drain over to the existing shower drain? There is about a 4" difference between the two, and I do not want to try and dig up anymore concrete at risk of breaking the cast iron pipe which is about 50 years old. I've already had to abandon the sink drain due to cracks in the cast iron and I don't want to mess with it anymore besides it's buried in about 12 inches of concrete. Hopefully someone can let me know if this is a bad idea, thanks.
dave94 is offline   Reply With Quote
Old 10-13-2012, 12:50 AM   #2
Your shower drain is trapped. Do not double trap your tub. I would consider building a platform to hold the tub so I could do the plumbing on top of the concrete. a pic would be real nice
paintdrying is offline   Reply With Quote
Old 10-13-2012, 09:52 AM   #3
you can use the existing drain but pipe the line over to where the tub is and reduce it down so you can use an 1-1/2 trap, the trap needs to be under the tub and like paintdrying said do not double trap it.
Old 10-14-2012, 12:06 AM   #4
I've tried 30 times to attach a picture but It woun't allow me to, any advise on that?
Old 10-14-2012, 12:31 AM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 452
See if this thread answers your image issues
How to resize photos to post them here.
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 11 12-30-2013 10:30 AM
Need help setting shower drain in existing slab drain hole! deedeedeeIY Kitchen & Bath Remodeling 9 05-11-2012 10:39 AM
setting a shower drain Jackets Plumbing 16 05-10-2012 09:48 PM
Sewage smell from shower drain, trap has water, vent was snaked and was clear clearasmud Plumbing 1 04-24-2011 07:28 AM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 03:25 AM
