Using Bleach To Prevent Sewer/lateral Clogs - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-09-2010, 09:52 PM   #1
Using bleach to prevent sewer/lateral clogs
I've heard using bleach is an effective means for preventing sewer/lateral clogs. Is it more effective in certain circumstances, tree roots, grease, other clogs.... How much is best to pour down the floor drain, how long should it sit there before being flushed out, and how frequently is best?
thanks
brokenhammer is offline   Reply With Quote
Old 06-10-2010, 03:56 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Do not use bleach if you're on a septic system. Using bleach for this purpose would not nearly be as effective as using a good enzyme-based, non-caustic drain cleaner such as DrainCare.
An enzyme-based drain cleaner will not harm you, your fixtures or pipes, but it WILL dissolve organic gunk, such as hair, soap scum, food particles, grease, etc. You just run warm water, pour in some DrainCare and let it eat overnight.
Then you flush the drain(s) down the next morning with hot water. I usually start this with a kettle of boiling water, and then let the hot water only run until the drain runs free.
For roots, there are several products to use, such as flushing a few cups of copper sulphate crystals down about three times a year.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
Finishing Basement, carpet install order? tigerbalm2424 Flooring 33 07-24-2008 08:35 AM
How can I prevent ice bursting my downspout? drh Roofing/Siding 6 02-17-2008 02:53 AM
Basement finishing smallcrpt Remodeling 18 11-12-2007 05:27 AM
Wood Bleach for Red Oak billinak Painting 1 08-04-2006 08:42 PM
