12-21-2012, 12:41 PM
#1
use a sewer snake to clean shower drain
12-21-2012, 01:01 PM
#2
Donuts stole my credit card. Your point being...
B
12-21-2012, 01:39 PM
#3
Best thing to try first is a ZIP-IT tool.........they are cheap......about $3. Made of flexible plastic with little barbs on the ends, this tool can be snaked down the drain and the little barbs will catch hold of the hair or obstruction and usually you can get the clog out that way. If that doesn't work then you can try a SMALL snake made for sink/shower drains. Of course, your plumber will kill you if you push the obstruction further down the drain lines...........
12-21-2012, 02:01 PM
#4
Master Plumber
don't waste your time use a jetter !
Experience is Knowing what to do next, Skill is knowing how to do it
12-21-2012, 03:02 PM
#5
Super Moderator
Is that something a homeowner can do?
12-21-2012, 03:33 PM
#6
call me E
Do you own a wet suit?
12-21-2012, 08:30 PM
#7
Super Moderator
I remember a post here a few months back when a plumber ruined a utility room blasting a main line by himself----he over looked a floor drain and created a fountain in the closed up utility room---customer was not amused.
12-21-2012, 08:39 PM
#8
call me E
I poked one down a roof vent to jet the main line but I had a hard time turning the sweep at the base of the stack - 6ft off the floor in the cellar. Well I got it past the sweep several feet and fired it up. What I didn't know is that I busted a hole in the 90 with the jetter head. Home owner runs outside and yells- Your flooding my cellar!
The Following User Says Thank You to TheEplumber For This Useful Post:
12-21-2012, 09:20 PM
#9
where is the shower located....only a 2"drain ... jetter???how about a handi electric hand snake? ben sr
12-21-2012, 11:43 PM
#11
Master Plumber
geeee Ben relax it was only a joke jetter in a tub really... OOPs i forgot roto rooter probably would
The Following User Says Thank You to Javiles For This Useful Post:
12-21-2012, 11:46 PM
#12
Master Plumber
Yes Mike homeowners can do it all we are no longer needed except on forums.
12-21-2012, 11:53 PM
#13
Super Moderator
We need to stick together and start charging!!!! What's the going rate?
12-22-2012, 06:27 AM
#14
"Nail-Bender"
The "going rate"?!?
$50/ hour for good advice -
$100/ hour for "questionable", advice!
The Following 2 Users Say Thank You to rossfingal For This Useful Post:
12-22-2012, 06:51 AM
#15
Super Moderator
Nathan can handle the billing---
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
