Use Oiled Oakum With Bonding Putty To Seal Cast Iron Hub? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-02-2011, 01:49 PM   #1
Rewards Points: 87
use oiled oakum with bonding putty to seal cast iron hub?
I just came back from HD. I tried to buy a 3" to 2" donut for my cast iron pipe replacement. They don't have it but i was recommended to use Oiled Oakum with Oatey's FIX-it STICK all purpose Bonding Putty to seal the hub joint. The procedure is the same as Oakum with Lead. Just use bonding Putty on the top instead of Lead.
I have to use cast iron hub.
Do you guys think his recommendation is OK?
diy001 is offline   Reply With Quote
Old 04-02-2011, 08:21 PM   #2
Rewards Points: 352
Bad idea. Go to plumbing supply house
plumberinlaw is offline   Reply With Quote
Old 04-03-2011, 09:38 PM   #3
Rewards Points: 29
Just because HD doesn't have it doesn't mean it doesn't exist. Go to a plumbing house and get a donut. Otherwise, Soil-O works good with Oakum.
MarkusAIC is offline   Reply With Quote
Old 04-04-2011, 09:32 AM   #4
Owner
LateralConcepts's Avatar
Either check a local plumbing supply or buy online.
http://www.google.com/products/catal...d=0CCkQ8wIwAg#
You might wanna grab some duck butter while you're at it..
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
pvc to cast iron hub using fernco-can't get it! What have I done Plumbing 10 01-22-2014 07:55 PM
cast iron or pvc treerat Plumbing 1 03-29-2011 06:38 AM
Main House Drain/Through Wall Cast Iron Pipe Docfletcher Plumbing 3 03-02-2010 07:41 PM
working with cast iron ericadami Plumbing 9 11-30-2008 12:45 PM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 10:07 AM
