Use Cold Water Line For Sink And Icemaker? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-12-2012, 09:41 PM   #1
use cold water line for sink and icemaker?
I'm in a condo and the water supply line is behind a 3 firewall so it's a pain to connect with. The cold water supply is already coming through the firewall to provide for the sink and there is an existing shut off valve. So if I could install a T after the shut off valve, the supply line would feed both the sink and the ice maker and the one shut off valve would shut off water to both the sink and the ice maker. The icemaker calls for a pressure between 30 and 120 PSI. Any thoughts on the feasibility of this approach will be much appreciated?
havaiisteve is offline   Reply With Quote
Old 04-12-2012, 10:47 PM   #2
Rewards Points: 13,968
How far away is the ice maker and the sink.
They make a double shut off so you could run a line to the sink so there would always be full pressure and the other line could be run to the ice maker.
One other benefit would be that if one needed shut off the other fixture could still be used.
Old 04-12-2012, 11:09 PM   #3
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
You need one of these.
The shut off will actually punch a hole in the pipe
For you.
sublime2 is offline   Reply With Quote
Old 04-12-2012, 11:16 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 796
Attachment 48918
For you.
Now you've done it - take cover
Old 04-12-2012, 11:18 PM   #5
That's a saddle valve, I'd never suggest someone use one. The reason being is they tend to plug up or leak. A double sut off would have full flow and not plug up.
Old 04-13-2012, 04:45 AM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
Thumbs down
Attachment 48918
For you.
We need a "No Thanks" button.
Coastal South Carolina
Old 04-13-2012, 06:07 AM   #7
DIY staff
Rewards Points: 7,174
Be nice guys---how much money have you all made on fixing broken saddle valves---???
They all fail --some with very expensive results---think--Job security
oh'mike is online now   Reply With Quote
Old 04-13-2012, 06:14 AM   #8
Rewards Points: 1,216
Do not use the saddle valve.
COLDIRON is offline   Reply With Quote
Old 04-13-2012, 10:13 AM   #9
Not enough pipe
Attachment 48918
For you.
There is not enough pipe exposed on the sink side of the firewall. It would have to be sealed in behind the firewall.
Old 04-13-2012, 10:15 AM   #10
Horizontally - just 3 feet. A double shut off sounds like an ideal answer. Is there a cheap tool I can use to measure the pressure...or am I worrying about a phantom problem? Our water pressure in the building is excellent. I'm on the 12th story of 24 stories.
Old 04-13-2012, 10:25 AM   #11
A "Handy Husband"
rjniles's Avatar
Install a 3/8" compression tee above the existing stop (shut off valve) using a 2" length of soft copper tubing. Connect the faucet supply line to the tee, connect the ice maker to the tee. Use copper tubing to connect the ice maker.
Old 04-13-2012, 11:40 AM   #12
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Originally Posted by havaiisteve
Horizontally - ...or am I worrying about a phantom problem? Our water pressure in the building is excellent. I'm on the 12th story of 24 stories.
Yes.
Another option.
It will allow you to shut water off to one without affecting the other.
Old 04-13-2012, 11:50 AM   #13
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
I Agree!
How do you hook up a water line for in icemaker? kennykenny Plumbing 8 06-22-2010 03:23 PM
Hook up water Line to Icemaker Delta69 Plumbing 1 01-12-2010 05:18 PM
Questions about icemaker and water line options littlehoov Appliances 2 11-04-2009 11:27 AM
My water line install to icemaker jrowny Plumbing 3 01-24-2009 02:32 PM
Help me locate a water line for my icemaker, PLEASE! curls00 Plumbing 11 07-23-2007 09:35 AM
