Old 01-26-2013, 10:09 AM   #1
usage gage
I think this is the right forum plumbing.
My son has a sprinkler system and it's possible one of the valves are not always closing all the time. he lives in AZ.
Is there a little site gage that I can install in the inlet line that shows a wheel or little arrow turning that indicates water passing through showing usage and a valve is open and leaking.
If i recall I saw one of these at sometime. and thought neat ! very inexpensive
Deck hand
deck hand is offline   Reply With Quote
Old 01-26-2013, 10:13 AM   #2
usage gage
If he's trying to use a globe or gate valve to to shut it off you can bet it's not shutting off at some point.
Replace it with a brass ball valve and it will shut off every time and should not leak.
Just Google "water flow indicator".
Old 01-26-2013, 11:14 AM   #3
retired elect/hvac/plumb
plummen's Avatar
usage gage
Are you talking about one of the zones in the system not shutting off?
Around here most sprinkler system have a seperate meter,you could just check the meter when system is off to tell if youre still using water or not
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 01-26-2013, 12:01 PM   #4
Doing it myself
Alan's Avatar
usage gage
What I do :
Make sure the sprinkler system timer is not set to run.
Turn off the valve to the sprinkler system.
Wait 5 minutes.
Turn valve to sprinkler system on.
If you can hear or feel water flow through the valve, then the sprinkler system is not holding pressure.
Journeyman Plumber
The Following 2 Users Say Thank You to Alan For This Useful Post:
deck hand (01-27-2013), plummen (01-26-2013)
Old 01-27-2013, 08:40 PM   #5
usage gage
Thank You This is what I was looking for But had no proper name for then indicator
Now I know what to buy.
Deck hand another problem solved by DIY and the gang
Clarification on cam-lock usage for private residential applications spowell71 Electrical 3 01-29-2013 02:35 AM
14 gage connected to 12 gage eugierom Electrical 15 04-22-2012 09:22 AM
help for gas usage Amy28 HVAC 1 04-27-2011 05:39 AM
Wire Gage for the Sub-Pannel jamiedolan Electrical 11 09-09-2008 12:33 PM
