Urinal Rough In And Drain Connection "Spud Flange" - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-27-2011, 11:48 AM   #1
crankcase's Avatar
Urinal rough in and drain connection "Spud Flange"
So I find this add on Craigslist and I was thinking of hanging it in the garage. Where can I find one of these flanges on my own as I am curious as to how much he is asking. I haven't heard back from him yet.
"I have a kohler white urinal that is in pretty good shape, along with a sloan chrome 3/4" flushometer valve. The valve alone new would be around $200, plus the cost of the urinal. I am asking $75 for both. All you would need is the eared flange for the drain connection, which I can get for you."
crankcase is offline   Reply With Quote
Old 12-27-2011, 12:09 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 564
You can get them from a plumbing supply house or I could get one off my truck The brass ones are 2" FIP so you need a 2" drain and a short galv. nipple to set the flange. Or you can get them in plastic also so it will glue onto the pipe- still need a 2" drain. I don't think the plastic ones are quit as common. You'll also need a urinal gasket
http://www.siouxchief.com/Drainage/R...ange-Kit.O1EDU
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
New drain connection dilema pF45 Plumbing 3 07-25-2008 11:17 AM
Bathtub drain and w&O overflow connection Manuel6 Plumbing 5 11-03-2006 11:23 AM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 02:30 PM
