Urinal Rough In - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-21-2012, 02:15 PM   #1
urinal rough in
any plumblers out there know the rough in on a kolher k-4960-et urnial? i need to know the spread on the all thread on the carrier for the bracket. the three all threads that hold the bracket on the finished wall. the two on top need to be a certain spread from the bottom one. i think its an inch off center but not sure. didnt get the paper work for the rough in and kolher is too busy to get back with me. any info is helpful. thanx. scott
purple01 is offline   Reply With Quote
Old 09-21-2012, 02:25 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
You must be using a carrier? Try JR Smith, Zurn or the supplier that you purchased from. That info comes with the carrier, not the urinal if I remember right
Old 09-21-2012, 07:39 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
rough in specs for the urinal : http://www.us.kohler.com/webassets/k...n/115947_1.pdf
Journeyman Plumber
Old 09-21-2012, 07:41 PM   #4
Doing it myself
Alan's Avatar
I'm kind of confused by what you refer to as a carrier bracket...... When I think of a carrier bracket, i'm thinking of a wall mount toilet.... urinals do not typically need that kind of setup.
Journeyman Plumber
Old 09-21-2012, 08:17 PM   #5
Plumber
Rewards Points: 452
It's the same idea as a wc carrier. I've used them with block walls and steel studs. (speced by arch/eng.) They're a pain to work with. On the top bracket, you stub out 1/4" allthread at the exact location of the urinal brackets- matching the hole pattern.
Another hassle is you do not use trap arms as the carrier posts will be in the way so your ground rough needs to be pretty accurate.
Old 09-24-2012, 05:40 PM   #6
OregonThe Shower me state
Turbogus's Avatar
Anyone reading this forum may think a residential urinal is unusual (right they are) but my Japanese in laws place (near Hammamatsu) the downstairs is traditional Japanese meaning on one side of a short hall is a benjo (a trough with running water set into the tiled bathroom floor that one squats over, and the other side of the hall a urinal~first time I ever saw one in a residential setting! Being a great beer drinker at the time I thought how wonderfully practical this is!
Turbogus is offline   Reply With Quote
Toilet and Shower Rough In Dimensions VikingDinKC Plumbing 16 05-13-2012 02:50 PM
Urinal rough in and drain connection "Spud Flange" crankcase Plumbing 1 12-27-2011 01:09 PM
Basement bathroom rough in plumbing ferris13 Plumbing 5 09-28-2009 11:06 AM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 12:04 PM
Replace a 10" rough in toilet with a 12" rough in Opie46 Plumbing 3 05-16-2009 12:27 PM
