-   -   urinal rough in (http://www.diychatroom.com/f7/urinal-rough-157519/)
purple01 09-21-2012 02:15 PM
urinal rough in
any plumblers out there know the rough in on a kolher k-4960-et urnial? i need to know the spread on the all thread on the carrier for the bracket. the three all threads that hold the bracket on the finished wall. the two on top need to be a certain spread from the bottom one. i think its an inch off center but not sure. didnt get the paper work for the rough in and kolher is too busy to get back with me. any info is helpful. thanx. scott
TheEplumber 09-21-2012 02:25 PM
199 Attachment(s)
You must be using a carrier? Try JR Smith, Zurn or the supplier that you purchased from. That info comes with the carrier, not the urinal if I remember right
Alan 09-21-2012 07:39 PM
rough in specs for the urinal : http://www.us.kohler.com/webassets/k...n/115947_1.pdf
Alan 09-21-2012 07:41 PM
I'm kind of confused by what you refer to as a carrier bracket...... When I think of a carrier bracket, i'm thinking of a wall mount toilet.... urinals do not typically need that kind of setup.
TheEplumber 09-21-2012 08:17 PM
199 Attachment(s)
It's the same idea as a wc carrier. I've used them with block walls and steel studs. (speced by arch/eng.) They're a pain to work with. On the top bracket, you stub out 1/4" allthread at the exact location of the urinal brackets- matching the hole pattern.
Another hassle is you do not use trap arms as the carrier posts will be in the way so your ground rough needs to be pretty accurate.
Turbogus 09-24-2012 05:40 PM
Anyone reading this forum may think a residential urinal is unusual (right they are) but my Japanese in laws place (near Hammamatsu) the downstairs is traditional Japanese meaning on one side of a short hall is a benjo (a trough with running water set into the tiled bathroom floor that one squats over, and the other side of the hall a urinal~first time I ever saw one in a residential setting! Being a great beer drinker at the time I thought how wonderfully practical this is! :)
