Urinal Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-29-2006, 07:06 PM   #1
World famous jerk.
urinal problem
This is a weird one.... The men's restroom at my shop has a urinal with a Sloan valve and a toilet with a Sloan valve. When you flush the toilet, the urinal will also flush occasionally. What gives? Is there some pressure issue? Or something wrong with one or both flush valves?
mdshunk is offline   Reply With Quote
Old 11-29-2006, 09:10 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Try replacing the diaphram in urinal see if that solves it.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 11-30-2006, 03:42 PM   #3
World famous jerk.
Went to the supply house for the diaphram. Aparently, there's 3 different one's just for urinals, and you need to match it up with the old one. I went and snagged the one out of the urinal, but the supply house is closed now. The diaphram by itself is about 5 bucks, and the whole repair kit is 20 bucks. I think that the kit is a good idea. I had to scour the shop for a Crescent wrench big enough to get the chrome top off that valve, so that I wouldn't have to use a pipewrench and put teethmarks on it. I hate that, when I see a Sloan valve all boogered up in a public restroom from the hack before who used the wrong tools to open it up with.
Old 11-30-2006, 06:17 PM   #4
Journeyman Plumber
Did you know the only thing that makes the difference in the types is the color of the ring that is stationary seen on the bottom side of a diaphram, there is
Black, white and blue, white is for closet, black is for urinal, blue is for water saver.
The plunger it's self is just that, it can be of any color.
I think and I could be wrong, the water saver diaphram can be used in either a closet or a urinal water saver 1.6 gal flush valve.
Old 12-01-2006, 05:48 PM   #5
World famous jerk.
Mine was Green. 1.0 gpf. Install went pretty smooth. So far, so good. Here's a scan of the paper in the kit.
Old 12-01-2006, 05:51 PM   #6
Journeyman Plumber
I thought about green also, but did not click at the time. Maybe there is no blue, damit I'm going color blind.
furnace problem captjack HVAC 8 11-23-2007 11:15 AM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 03:16 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
A/C Thermostat Problem therumblefish HVAC 7 11-01-2006 08:08 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
