Old 12-05-2012, 11:53 AM   #1
Question
Urgent! Need replacement sump pump recommendation ASAP
Thank you for reading my request.
We had the following sump pump, which worked perfectly for years.
Water Ace model R3S 1/3 HP submersible sump pump. 115 volts, 6.5 amps, 60 hertz.
My local Lowe's no longer carries it. I need alternatives that I can get at my local Lowe's, Home Depot or Busy Beaver.
Can you please recommend comparable or better makes and models?
Also, please note, some models we tried early on (don't have a record of make or model) would not run at all on the electricity we had coming into the house because of the amperage or something like that.
I tried asking the guy at Lowe's but he was not at all knowledgeable. I need to get one today.
DGeer is offline   Reply With Quote
Old 12-05-2012, 12:36 PM   #2
http://www.sumppump-reviews.net/
A sump pump should be on it's own 12-2 20 amp circut.
If a sump is that important then something else is wrong.
Working gutters, grade running away from the house, no mulch or flower beds againt the foundation.
Water proof the outside of the foundation.
In extreame cases you may need a french drain.
The idea is to prevent water from getting in, in the first place not have to deal with it once it's inside.
Old 12-05-2012, 01:10 PM   #3
If your sump fills up so fast that you need a pump today, you have bigger problems. I've never even heard of a Water Ace. Common brands are Taco (pronounced TAY-co) and Zoeller.
md2lgyk is online now   Reply With Quote
Old 12-05-2012, 01:34 PM   #4
Question
Who sells Taco and Zoeller?
Old 12-05-2012, 02:16 PM   #5
SInce you chose not to include to add your location it's hard to suggest a place to buy them.
There's people on this site for the 4 corners of the globe.
Just go on there web site to find a local dealer.
Old 12-05-2012, 02:20 PM   #6
Super Moderator
Zoeller is sold at plumbing supply houses----very good pump---many would say it's the longest lasting---
Depot has
Rigid---those are very dependable---
Old 12-05-2012, 08:09 PM   #7
wayne ..liberty,, also good pumps....ben sr
Tags
sump pumps
Sump pump drain into buried downspouts Chokingdogs Plumbing 1 11-07-2012 12:09 PM
Backup sump pump & check valve issues Richo Plumbing 7 10-14-2012 09:44 PM
understanding the numbers on a sump pump and which one to buy ksimpson Plumbing 0 09-09-2011 08:51 AM
On Off Indicator For Outside Sump Pump Lawrence Coppar Electrical 31 03-29-2009 02:01 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 10:36 AM
