-   -   Urgent! Need replacement sump pump recommendation ASAP (http://www.diychatroom.com/f7/urgent-need-replacement-sump-pump-recommendation-asap-165656/)
DGeer 12-05-2012 10:53 AM
Thank you for reading my request.
We had the following sump pump, which worked perfectly for years.
Water Ace model R3S 1/3 HP submersible sump pump. 115 volts, 6.5 amps, 60 hertz.
My local Lowe's no longer carries it. I need alternatives that I can get at my local Lowe's, Home Depot or Busy Beaver.
Can you please recommend comparable or better makes and models?
Also, please note, some models we tried early on (don't have a record of make or model) would not run at all on the electricity we had coming into the house because of the amperage or something like that.
I tried asking the guy at Lowe's but he was not at all knowledgeable. I need to get one today.
joecaption 12-05-2012 11:36 AM
http://www.sumppump-reviews.net/
A sump pump should be on it's own 12-2 20 amp circut.
If a sump is that important then something else is wrong.
Working gutters, grade running away from the house, no mulch or flower beds againt the foundation.
Water proof the outside of the foundation.
In extreame cases you may need a french drain.
The idea is to prevent water from getting in, in the first place not have to deal with it once it's inside.
md2lgyk 12-05-2012 12:10 PM
If your sump fills up so fast that you need a pump today, you have bigger problems. I've never even heard of a Water Ace. Common brands are Taco (pronounced TAY-co) and Zoeller.
DGeer 12-05-2012 12:34 PM
Where would you find a Taco or Zoeller sold?
Who sells Taco and Zoeller?
joecaption 12-05-2012 01:16 PM
SInce you chose not to include to add your location it's hard to suggest a place to buy them.
There's people on this site for the 4 corners of the globe.
Just go on there web site to find a local dealer.
oh'mike 12-05-2012 01:20 PM
Zoeller is sold at plumbing supply houses----very good pump---many would say it's the longest lasting---
Depot has
Rigid---those are very dependable---
ben's plumbing 12-05-2012 07:09 PM
wayne ..liberty,, also good pumps....ben sr
