Urgent! How To Fix This Tap - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-18-2013, 07:34 AM   #16
Retired from the grind
Rewards Points: 6,652
I actually found a pebble under the valve stem, for our cold water tap, for our wash machine. Looks like the OP is going to have to shut water off, then remove the valve stems and see what is going on. Best case scenario, need to change them out. Worst case scenario, you get to tell the significant other, that you are going to be busy, so you are unable to go do something with them.
Old 01-18-2013, 07:49 AM   #17
Sorry, do you mean one to hold behind the red rubber ring (the pipe) and one to hold the part in front of the red rubber ring (the valve)?
Originally Posted by joecaption View Post
Have the main water supply shut off and relieve the pressure on the line by opening up a faucet before working on this!!!
Going to need two wrenchs, one to hold the pipe and one to turn the valve.
smoyi is offline   Reply With Quote
Need urgent help with relocation of shower P trap vetting Plumbing 17 06-02-2012 10:42 PM
need urgent advice, ceiling paint gagaliya Painting 12 09-27-2009 02:49 AM
Urgent Breaker Replacement Problem remodel-virgin Electrical 20 07-01-2009 07:49 PM
Urgent Bathroom Floor Repair tman2009 General DIY Discussions 2 12-07-2008 08:53 PM
Broken Diverter? Need HELP! URGENT!!! esadiek Plumbing 2 09-07-2008 08:31 PM
