Urgent! How To Fix This Tap - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-17-2013, 04:02 AM   #1
Urgent! How to fix this tap
Both taps are connected to the washing machine. I was going to turn off the water to fix the washing machine, but found out that the hot water tap (on the left of picture) cannot be turned off. I tried to screw it, but it's so hard to do.
Much appreciated if anyone could help.
See attachments.
Urgent! How to fix this tap-20130117_194948.jpg   Urgent! How to fix this tap-20130117_194956.jpg
smoyi is offline   Reply With Quote
Old 01-17-2013, 05:02 AM   #2
its due to water hardening
Hi, this is a common problem with tap being not operated frequently; as heated water causes cabonate and sulphate to be deposited. Its the time to change its valve or you can apply little hammer and try to rotate it
prateekgupta is offline   Reply With Quote
Old 01-17-2013, 06:40 AM   #3
DIY staff
Rewards Points: 7,174
I agree---That is a threaded pipe---replace the valve---use a 1/4 turn ball valve
Old 01-17-2013, 06:43 AM   #4
Thanks for your response, but it's so hard to rotate it.. just need to keep trying I guess
Old 01-17-2013, 06:47 AM   #5
I know nothing about plumbing, but I am sure that I should be able to get the turn ball valve from the shop.. Thanks..
Old 01-17-2013, 06:53 AM   #6
apply little hammer
just knock the valve from all directions with some light weight hammer and then rotate
Old 01-17-2013, 08:08 AM   #7
Master Plumber
Javiles's Avatar
Rewards Points: 984
As your tapping and turning start praying that the plumbing behind the wall is in good shape and well secured, have a back up plan..
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 01-17-2013, 11:08 AM   #8
Rewards Points: 12,886
Have the main water supply shut off and relieve the pressure on the line by opening up a faucet before working on this!!!
Going to need two wrenchs, one to hold the pipe and one to turn the valve.
Old 01-17-2013, 01:57 PM   #9
Roofmaster
Rewards Points: 2,172
Turn off the water at the main. Remove the supplies to the washer. Cut the escutchen with your trusty dremmel tool. Put a pipe wrench on the nipple, remove the valve and throw it as far as you can into the landfill. Install new ball valves, and new braided washing machine supplies. I have never seen those clear supply hoses, nor would I ever use them.
Old 01-17-2013, 04:14 PM   #10
Thanks all for your response. I am going to try again today. Wasn't successfully yesterday.
Old 01-17-2013, 04:37 PM   #11
Those lines are way under sized and are sure to fail at some point.
Go back and add your location to your profile.
This may not be the US I've never seen a washer hooked up that way before.
Old 01-17-2013, 05:47 PM   #12
Roofmaster
There is no try Grasshopper, there is only do.
Old 01-17-2013, 07:38 PM   #13
DIY staff
This member is from 'Down Under' (Australia) which will explain the unusual plumping lines---
Old 01-17-2013, 10:09 PM   #14
Roofmaster
Is that kind of hose used in Australia a lot? I'm surprised you aren't "Down Under" the water, most of the time.
Old 01-17-2013, 11:12 PM   #15
Plumber
TheEplumber's Avatar
Rewards Points: 358
Looks like grey PB... I hear some people still use it
Need urgent help with relocation of shower P trap vetting Plumbing 17 06-02-2012 11:42 PM
need urgent advice, ceiling paint gagaliya Painting 12 09-27-2009 03:49 AM
Urgent Breaker Replacement Problem remodel-virgin Electrical 20 07-01-2009 08:49 PM
Urgent Bathroom Floor Repair tman2009 General DIY Discussions 2 12-07-2008 09:53 PM
Broken Diverter? Need HELP! URGENT!!! esadiek Plumbing 2 09-07-2008 09:31 PM
