-   -   Urgent! How to fix this tap (http://www.diychatroom.com/f7/urgent-how-fix-tap-169354/)
smoyi 01-17-2013 03:02 AM
2 Attachment(s)
Both taps are connected to the washing machine. I was going to turn off the water to fix the washing machine, but found out that the hot water tap (on the left of picture) cannot be turned off. I tried to screw it, but it's so hard to do.
Much appreciated if anyone could help.
See attachments.
prateekgupta 01-17-2013 04:02 AM
its due to water hardening
Hi, this is a common problem with tap being not operated frequently; as heated water causes cabonate and sulphate to be deposited. Its the time to change its valve or you can apply little hammer and try to rotate it
oh'mike 01-17-2013 05:40 AM
I agree---That is a threaded pipe---replace the valve---use a 1/4 turn ball valve
smoyi 01-17-2013 05:43 AM
Thanks for your response, but it's so hard to rotate it.. just need to keep trying I guess
smoyi 01-17-2013 05:47 AM
I know nothing about plumbing, but I am sure that I should be able to get the turn ball valve from the shop.. Thanks..
prateekgupta 01-17-2013 05:53 AM
apply little hammer
just knock the valve from all directions with some light weight hammer and then rotate
Javiles 01-17-2013 07:08 AM
As your tapping and turning start praying that the plumbing behind the wall is in good shape and well secured, have a back up plan..
joecaption 01-17-2013 10:08 AM
Have the main water supply shut off and relieve the pressure on the line by opening up a faucet before working on this!!!
Going to need two wrenchs, one to hold the pipe and one to turn the valve.
jagans 01-17-2013 12:57 PM
Turn off the water at the main. Remove the supplies to the washer. Cut the escutchen with your trusty dremmel tool. Put a pipe wrench on the nipple, remove the valve and throw it as far as you can into the landfill. Install new ball valves, and new braided washing machine supplies. I have never seen those clear supply hoses, nor would I ever use them.
smoyi 01-17-2013 03:14 PM
Thanks all for your response. I am going to try again today. Wasn't successfully yesterday.
joecaption 01-17-2013 03:37 PM
Those lines are way under sized and are sure to fail at some point.
Go back and add your location to your profile.
This may not be the US I've never seen a washer hooked up that way before.
jagans 01-17-2013 04:47 PM
There is no try Grasshopper, there is only do.
oh'mike 01-17-2013 06:38 PM
This member is from 'Down Under' (Australia) which will explain the unusual plumping lines---
jagans 01-17-2013 09:09 PM
Is that kind of hose used in Australia a lot? I'm surprised you aren't "Down Under" the water, most of the time.
TheEplumber 01-17-2013 10:12 PM
199 Attachment(s)
Looks like grey PB... I hear some people still use it
