URGENT! Hot Water On Demand Questions - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-05-2009, 07:54 AM   #1
URGENT! Hot water on demand questions
I am looking for advice: We are installing solar panels and switching from oil heat to electric heat as well as to hot water on demand LP water heater. Since the oil furnace has been removed, is it possible to vent the gas water heater vertically through the unused furnace chimney?
Thank you all for your advice.
ejablonka is offline   Reply With Quote
Old 08-06-2009, 07:44 AM   #2
Rewards Points: 1,536
Yes you may route the gas water heater vent using the former furnace chimney except when the water heater instructions say otherwise. For example the water heater venting components may recapture or recycle so much of the heat from the exhaust gases that the gases will no longer rise up the chimney and a special vent pipe (diameter wise) and routing is needed.
Old 08-06-2009, 07:54 AM   #3
Urgent
Thank you so much for the information. Now I will be able to discuss the situation intelligently and understand what the experts are talking about.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 10:33 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
