Urgent Help Need - Kitchen Sink Valve Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-11-2013, 10:59 AM   #1
Rewards Points: 107
Urgent help need - Kitchen sink valve leaking
We have 3 valves under sink. Yesterday, my mother told me it's leaking and I found only 2 were leaking from handle area. So, replaced them with new ones. Then this morning, other valve was leaking and can't seem to understand exactly what is problem to cause the problem in sequence.
I am petit woman, so it was challenge to replace these valves because it was located very deep behind food grinder.
But when I checked both new valves, seems no issue and no leakage.
I am not 100% determined where this leak is coming from.
I know the other valve which I did not replace had leak from valve. But possible there's other area too.
If we hve too strong of water pressure, can this cause to leak?
What can be issue to cause value leaks?
I am not sure why all of a sudden this is happening. We live in Seattle WA and it is winter, but it is not a freezing cold.
I am sure there's other possibilities, but am thinking it has something to do with water pressure because when I turned on main water valve, I did turn all the way.
If you have suggestion, please help me understand better.
I am going to look for plumber to call.
Andee77 is offline   Reply With Quote
Old 02-11-2013, 11:40 AM   #2
Rewards Points: 13,712
Since we have no idea what the valve looks like I'll make a guess.
Most leak around the packing nut where the shaft comes out.
Just snug up the nut and it stops leaking. No need to over tighten.
TPR valve leaking - closed system? Hidden check valve? Pressure mystery dustout Plumbing 0 09-23-2012 05:36 PM
Replace Kitchen Sink Cut-off Valve MBVILLA Plumbing 7 08-16-2012 06:08 AM
Venting inadequate with AAV Kitchen sink DownStream Plumbing 1 07-31-2012 11:57 AM
pressure relief valve is leaking on boiler wlmpdiycr HVAC 65 10-26-2011 05:00 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
