-   -   Upstairs toilet pipe noise (http://www.diychatroom.com/f7/upstairs-toilet-pipe-noise-689/)
bliss 06-06-2005 07:40 AM
I have an upstairs toilet that when flushed after sitting for a while makes a banging noise after it travels through the pipe for about 5 seconds. If you flush it a couple of more times right afterward the noise will go away and won't return the rest of the day. It's not used much as it is the guest bathroom. Thanks for any help. I don't want to tear out the ceiling if I don't have to.
Tomm 06-11-2005 12:32 AM
This may not be the toilet flush making the noise. It could be the water supply line because after setting for a while, it could be taking in air for some reason, more likely in the fill valve in the tank because that is the part of the system that is not under sealed pressure. A replacement valve is a pretty inexpensive repair, so it may end there. ---Please post if this remedies the problem, or not.
lanie 08-24-2005 02:58 AM
We are also having this same problem. After we flush our upstairs toilet we hear a bang in the pipe, this is before the toilet has filled & shut off so I am guessing it is not water hammer. The pipes also seem to change direction where it seems to make this noise. Anyone have any thoughts :confused:
Teetorbilt 08-24-2005 12:47 PM
It could be the trap drying out causing a one time water hammer. Try pouring a gallon or two of water into the bowl before the next use and see what happens.
plumguy 08-24-2005 06:11 PM
You need to replace you're fill valve on you're toilet. Fluidmaster 400A is good choice and can be found at just about ant hardware store.
The noise you are hearing is most likely from worn or loose washer in you're existing fill valve.
Water hammer is caused by quick acting valves and excessive pressure.
Potable water systems are a closed system, which means that there is no air in them!!! Atmospheric pressure would have to be greater than the water pressure for air to go into the lines...just is'nt going to happen!!!!
erockybalboa 05-19-2006 05:59 PM
Toilet repair
Today we are replacing a disabled toilet. It leaks and it also leaks down at the base where it's cracked at, so we're just going to replace the whole entire thing. If you buy a toilet that is- it's called a toilet in a box. It has everything you need to replace it, the seat, and the bolts and everything. Most important to remember is you want to clean around the toilet and the toilet with disinfectant or just pure bleach. And you want to remember to clean the whole entire three feet around it because you don't want to cut yourself.
And then, while that's doing its job you want to drain out all the water in the toilet. So you want to turn off the valve right here. If your valve doesn't turn off, you can either turn it off at the street or call a plumber. If you flush it and then hold it, hold the handle up until it stops draining water. And then you're going to fill up any bucket or anything with about two gallons of water because the toilet always retains some water. You want to pour it into the bottom of the toilet and it will flush the rest of the water out. It will however keep about a gallon in the pee trap. So when you carry it out you want to make sure that you have it level. Because if you don't have it level, it's going to spill out the rest of the water. And that's how you would prepare the area to remove a broken toilet.
Atricaudatus 05-28-2006 10:08 PM
Teetor, unless the bowl has dried out completely, then pouring more than 1.6 gallons of water in it will simply cause it to flush.
luvr29 12-05-2006 03:00 PM
Replacing broken toilet
Regardless of your needs, installing a new toilet or replacing one that has seen better days is relatively easy. There are just a few steps and it can all be completed in one day.
Selecting a new toilet
In most states across the Untied States, new toilets must allow for only one and a half gallons of water to flush at one time. This not only saves the environment with every flush, it also saves you each month with your water bill. You will find that most community building codes also require these new toilets. It is always best to check with your local community before installing the new toilet. The only thing left is to choose a style or color that best suits your family, needs and interior design scheme of your bathroom.
Getting started
If you are installing a new toilet in a new location where one did not exist before you can skip this part. Replacing an old toilet has only a couple of extra steps from installing a toilet in a new location.
Before you try to remove the old toilet, you need to be sure the water has been shut off. Behind the toilet (and sometimes hidden in the base cabinet adjacent to the toilet) is the water shut off valve. If you remember the old phrase, “Lefty Lucy – Righty Tighty”, you will be able to know which way to turn the valve to cut off the water supply. Turn to the right to close the valve. You will need to be sure the water is turned off and you will need to empty the tank, so flush the toilet twice. This helps to ensure you got most of the water out. There will be a bit of remaining water in the tank so have towels or news paper on the floor to help mop up the water when the tank is removed.
Removing the old tank
Follow the water supply cut off valve to the tank of the toilet. Take an adjustable wrench and clamp it onto the outside supply tubing on the coupling nut. With a pair of rib joint pliers, inside the tank, grab the other nut and turn left to loosen. You may need to hold the outside nut and adjustable wrench with your other hand to stabilize.
Once you have the water supply disconnected, it is time to remove the tank. With the same technique you just used to remove the supply line, you need to hold the mounting bolt nut under the tank, while inside the tank you unscrew the mounting bolt from the main body of the toilet. This will release the tank. Simply set the tank on the floor with some form of cushion to protect your flooring. Newspaper or old towels will do just fine.
Next you will need to remove the floor bolts that hold the main toilet body to the floor. Once you have these off, it is time to pull the toilet off the floor. The toilet is attached not only by the floor bolts, but also by adhesive. You will need to rock the toilet back and forth while leaning it forward to pry it loose.
Once the old toilet has been removed stuff a rag into the exposed pipe. This helps keep the sewer gasses from entering the room and keeps objects from falling into it. You can use a paint scraper or any flat tool to scrape the old adhesive remains from the floor and pipe gasket. Try to clean as well as possible as this will help with better adhesion for the new toilet.
Installing a new toilet
If you are installing a new fixture where there was no fixture before, supply line pipes will need to be installed. You will need to call a professional plumber to do this for you as it is very involved and dangerous. Once you have the pipes installed, installing the new fixture is a snap!
Lay some newspaper or old towels on the floor. Flip the new fixture over and lay down on the paper or towel to protect your flooring and to expose the underside. The underside of the toilet will have a hole, called a horn. This is where the water leaves the toilet to the sewer. You need to place a new wax gasket on this horn. Most new toilets come with this wax gasket.
Flip the bowl back over and place the horn of the toilet into the floor pipe. Rocking it back and forth will help insure of a good fit. Once you have the toilet bowl in place, you will need to level it while attaching the floor bolts at the same time. To do this, place the bolts through the holes into the floor loosely. With a level on top of the bowl, slowly tighten the floor bolts. You want the bowl to be tight to the floor, but not too tight as to crack the porcelain of the bowl. If you are unable to level the bowl and have the floor bolts tight at the same time, you may need small plastic shims to level the bow.
Attaching the tank
Some new toilets are one piece, meaning the tank and the bowl are not separated into two parts. However traditionally toilets do have a separate tank. Attaching the tank is even easier than the bowl.
Your new toilet will come with a flush valve, this is the mechanical contraption that fits inside your tank that attaches to the handle outside of the tank, and flushes the water. Assemble this according to the manufacturer instructions and attach inside your tank before installing the tank.
Your tank should come with a mounting cushion. This is a rubber piece that is laid under the tank to protect the tank from rubbing against the bowl, subsequently cracking either one. Lay the tank onto the bowl, being careful to position the two bolt holes over the matching holes underneath. Insert the mounting bolts and tighten. There may be gaps where your mounting bolts are, so you will need to fill any gaps with plumber’s putty, available at any hardware store.
The only thing left is to hook up the water supply. Take the water supply line and screw to the bottom of the tank. Turn the water supply valve back on and flush! Congratulations! You have just installed your first toilet!
great 01-10-2008 08:55 AM
Hi. I'm new here and I have to say that I'm glade that I've found this thread.It's very interesting and useful Thanks for the information.
