Old 06-12-2011, 11:14 AM   #1
wab
Upstairs Toilet Drain
The upstairs toilet began to leak and I decided to fix it. In my investigation I found a number of problems. Here is what concerns me. The toilet drain Y's off to the vent. The vent appears to be a 3". After removing a section of the floor I found the drain for the 2 sinks share the same line (3") but in the center it Y's off to the main line that is smaller (2"). The Y is pointed to the sinks. This means the sewer water from the toilet must go down the 3 inch pipe and then make a 235 degree turn to get down the smaller drain. Is this right? Do I need to replace the smaller line or can I T into the larger line or reverse the Y?
wab is offline   Reply With Quote
Old 06-12-2011, 11:53 AM   #2
Doing it myself
Alan's Avatar
A picture or drawing would be helpful on this one.
Journeyman Plumber
Old 06-12-2011, 01:40 PM   #3
wab
Attached is the quick drawing.
Old 06-12-2011, 01:48 PM   #4
the Musigician
DangerMouse's Avatar
I do not think the 'main drain' is a 2". Are you absolutely certain? Can you post photos?
Everything else looks pretty much normal though.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 06-12-2011, 03:58 PM   #5
wab
I am guessing at the size of the main drain. It could be 2.5" but it is clearly smaller than the drain going from the toilet. Should the Y really point to the sinks? Here is a picture.
Old 06-12-2011, 04:14 PM   #6
the Musigician
I see a 2" to a 3" wye and the rest is 3" standard drain. Looks perfectly normal to me.
Where does it reduce from 3" to 2"?
DM
Old 06-12-2011, 04:43 PM   #7
wab
The 3" pipes from the toilet and sinks drain into the 2" pipe which then drains to the sewer.
Old 06-12-2011, 04:50 PM   #8
the Musigician
Do you have a picture of where this junction goes from 3" to 2"? It seems very unusual to me.
DM
Old 06-12-2011, 07:58 PM   #9
Doing it myself
Alan's Avatar
I'm confused how you determined which direction the piping is going if that's all you can see.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
wab (06-13-2011)
Old 06-12-2011, 09:08 PM   #10
call me E
TheEplumber's Avatar
That branch on the 3x2 y is probably the toilet vent. Not a drain. You do not reduce pipe sizes downstream on drain lines.
The Following User Says Thank You to TheEplumber For This Useful Post:
wab (06-13-2011)
Old 06-13-2011, 06:10 AM   #11
Thats my guess too
mikeylikesit580 is offline   Reply With Quote
Old 06-13-2011, 04:21 PM   #12
wab
After digging further it now appears that the drain for the sinks IS the main drain. Sorry but with everything I have had to do in this house (nothing is the way it's suppose to be) I panic when something doesn't look right. It turns out the 2" is the drain from the bath.
Other question.
A long time ago I was told by a plumber not to sweat copper after it had been in use for a long time. The reason was the hard water caused calcium to build up in the line and if you heated it up it could cause the copper to develop pin holes. Is this true?
Old 06-13-2011, 11:39 PM   #13
Doing it myself
Alan's Avatar
Other question.
Pictures are worth 1000 words each. Please post more.
Journeyman Plumber
Old 06-14-2011, 12:15 AM   #14
call me E
Other question.
Never heard that before. Sounds like he wanted to sell you some new pipe.
Tags
toilet installation, upstairs
Drain line for toilet PatSea Plumbing 6 06-11-2011 11:53 PM
help: distance from upstairs toilet vent stack to a new downstairs 1/2 bath Heikks2002 Plumbing 3 01-15-2010 11:21 AM
Toilet Flush, Shower Drain Trash plejeune Plumbing 3 07-13-2008 11:05 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
