Upside Down Water Nozzle (outside) - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-21-2013, 08:49 PM   #1
Upside down water nozzle (outside)
We recently purchased a home and found out that the outside water nozzle (where you would connect a garden hose) is facing up. It works fine, but we're afraid that the water won't drain properly and we'll be left with frozen and cracked pipes in the winter.
Is there an easy solution? I'm assuming the previous owners had it this way the entire time they've owned the home so it may not be an issue...but perhaps?
Thanks for whatever advice you can give!
Umass02 is offline   Reply With Quote
Old 10-21-2013, 09:01 PM   #2
Rewards Points: 6,652
Cut the line inside, unscrew the fixture from the outside of the house, and flip back over. You can use a "Shark Bite" or Compression fitting to reassemble the piping, if you are not comfortable with using a torch.
Old 10-21-2013, 09:17 PM   #3
Rewards Points: 13,450
Got a picture? Tried just tightening it more?
Need to see it you see if it's sweated or threaded on.
Is it steel, copper, Pex plumbing?
Tags
nozzle , outside faucet , upside down , water
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
