Uphill Sewage? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-14-2009, 03:51 AM   #1
Uphill Sewage?
I have a building on my property that sits very much downhill from my home. I would like to make this space into an apartment. The building was a cabin at one point and has a septic field. My problem is I am located on a lake and have been unable to locate the field, "which is now illegal to use near the lake". So my problem is I need a way to move sewage from this building uphill to the line connected to my home. What have been able to find is only large scale lift systems. I need something much smaller "I think anyways". We are talking a one person dwelling with a kitchen sink, bathroom sink, shower, and toilet. I'm hoping to find something with a small footprint if possible! Any links or input would be greatly appreciated!! I'm also working on a budget as most people in these interesting times, thanks!
robmac is offline   Reply With Quote
Old 04-14-2009, 04:07 AM   #2
Rewards Points: 12
Something like this: http://www.plumbingsupply.com/sewage.html
Goggle "sewage ejector pump"
KeepItSimple is offline   Reply With Quote
Old 04-14-2009, 04:11 AM   #3
Rewards Points: 902
I would look into sewage mascerating systems - or sewage grinder, with the ability to lift. Pipe it as far as you can length and height-wise, and dump into another sewage "sump", lift again, etc... until you reach your sewer line.
LawnGuyLandSparky is offline   Reply With Quote
Old 04-14-2009, 04:16 AM   #4
KeepItSimple thanks for the link! LawnGuyLandSparky so your saying install multiple units like KeepItSimple linked to? Or a unit like that into a tank with another pump further down the line? I will try and get photos up asap of the space and path of travel I am dealing with.
Old 04-14-2009, 04:44 AM   #5
Rewards Points: 902
As many as you need to get the job done. Keep in mind a pump can only lift water 18'. You'll have to get creative if your grade is steep, or you have freezing weather, etc...
Old 04-14-2009, 06:55 AM   #6
Rewards Points: 150
2 inch grinder pump reduce to 1 1/4 pipe outside the house and enjoy.
al's sewer is offline   Reply With Quote
Old 04-14-2009, 08:16 PM   #7
How long on average do you think this would carry water? I'm dealing with a fairly steep grade at the start of the uphill rise. If I require to many sumps this may not be a possible project. Without destroying my yard that is haha.
Old 04-15-2009, 09:15 AM   #8
Rewards Points: 150
here are a couple pumps I have used in the past. Contact them and tell them about your project and they well guide you and answer all your question.
http://www.google.com/products?sourc...num=1&ct=title
Old 04-26-2009, 11:35 PM   #9
BULLETflight7's Avatar
NOT A PROBLEM AT ALL!!!
there are a couple things to look at... pipe run distance and elevation change...
a grinder pump can lift water up to 185' vertical (e-one pumps www.eone.com). myers, barnes, can do around 110'-125' vertical lift. grinder pumps are normally 1-1/4" discharge. if your house already has a grinder station that pumps to the city sewer, pump the new addition to it, therefore you wont be charged for a new sewer tap fee.
-jason
BULLETflight7 is offline   Reply With Quote
Old 07-30-2010, 10:05 AM   #10
The two biggest variables are the distance the pipe runs from the ejector to the gravity line and the elevation change between those two points. You want a pump station that can handle the whole distance and elevation without adding additonal pumps along the way. These variables will determine the pump selection and basin size. The higher elevation you need to pump, the larger the pump needs to be, which in turn also effects the basin size, especially if you go with a duplex system with two pumps. A duplex system is recommended for a whole house application in case one pump goes down. Larger pumps also need to run longer to avoid short cycling which burns out the motor faster than a small pump. This will also effect basin size. The power demand is another thing to take into consideration. Larger ejectors have higher electrical demands, especially at startup when the motor first turns over and is trying to push against the high head of water sitting against the check valve in the discharge line.
The Engineer is offline   Reply With Quote
Old 07-30-2010, 10:33 AM   #11
Owner
LateralConcepts's Avatar
robmac -
There are a lot of things to consider. This is an expensive project even if you plan to do it yourself. You need to find a wholesale supply in your area that specializes in pumps. They'll have charts telling giving you the specs based on how far and how high you have to pump. The Liberty Omnivore is an awesome pump, and would most definitely do the job. Might be overkill though depending on your situation.
http://www.libertypumps.com/Products...p=69&s=26&c=19
If you're in an area that freezes you'll need to check your local code requirements to determine the depth of your tight line running up to the gravity line. What are the soil conditions? If you're near the lake, is there any large rock in the way that would prevent you from digging a trench 3' deep or so all the way to the gravity line?
You'll also need a dedicated circuit to run the pump, and a quality control panel like Orenco to run the system which will require electrical work. http://www.orenco.com/
If you're abandoning an old septic system the local health department will be involved. Most likely requiring you fill or crush the old tank.
This is not an exhaustive parts or equipment list of course, just the big things. Basin, pump, panel, pipe, fittings, check valves, ball valves, mini-excavator, ditch witch, etc, etc, etc
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 07-30-2010, 10:43 AM   #12
This thread is over a year old......it was "bumped" by a spammer
Old 07-30-2010, 10:47 AM   #13
Owner
Haha oh geez. Thanks for the heads up. Didn't notice 'til you said somethin. April '09.
Lateral
(208) 818-8241
Sewage extraction tank installation. CDN007 Plumbing 2 01-15-2009 06:00 PM
Sewage ejector -- Bathroom in Basement assassinmunky Plumbing 7 07-26-2008 10:22 AM
Sewage Lid + check valve majorchamp Plumbing 2 07-07-2008 11:06 AM
Sewage Under House: How To Remove Smell rajivsab Plumbing 5 11-27-2007 08:31 PM
sewage building code for home owners aokss Plumbing 9 09-11-2006 07:37 PM
