Update To Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-21-2013, 09:26 PM   #16
Master Plumber
Javiles's Avatar
Rewards Points: 996
We want you and your family first to be safe and second have well working system.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-22-2013, 05:51 AM   #17
Rewards Points: 1,216
Why didn't you reuse the black pipe from the first picture? Why did you change it to Galvanized? Take it apart and pipe it with Black and use the recommendations suggested.
Take that copper off the TP and run a straight piece right down to the above the floor and forget it.
"Just Do It"
Coldiron Out
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
