Update To Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-20-2013, 09:45 PM   #1
Update to water heater
Added drip-legs to the valve and the pressure relief valve
GRed is offline   Reply With Quote
Old 02-21-2013, 06:13 AM   #2
Rewards Points: 1,216
Don't like the looks of either of the piping connections.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 02-21-2013, 06:21 AM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 994
there are three threads on this heater install.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-21-2013, 06:31 AM   #4
Thanks Javiles. GRed call a pro to do the work before you get burnt or blow the joint up.
The TP has to be re-piped properly and the gas drip needs attention.
Please listen to the past recommendations, it looks like you didn't get it.
Old 02-21-2013, 07:44 AM   #5
Rewards Points: 1,506
Drip leg does not apply to water pipes.
The pressure/temperature relief valve must have a pipe extension extending down to within 3" of the floor.
Old 02-21-2013, 07:54 AM   #6
Rewards Points: 13,472
Anyone else think that gas supply line looks like it's to small?
I like to install a shut off for the gas supply right where it connects to the wall.
Old 02-21-2013, 06:50 PM   #7
water heater
well I confirmed the gas side of this.. and its not only came from a licensed plumber.. but now I happen to look in the horses mouth(the manual) and look what I found...geee..drip leg or sediment trap also with older homes that were grandfathered in and T&P ran up hill to put a T in add 6" leg w/cap and I was told no more that 61/2 long with an 1/8 hole in the cap no more than that so I guess its not going to blow up...btw there is a gas shut-off towards the back just cant see it on that line in the pict.
http://www.waterheaterexplosions.com/R_Drip_Leg.html
http://activerain.com/blogsview/2660...-water-heaters
Name:  Screen Shot 2013-02-21 at 5.26.13 PM.jpg
Old 02-21-2013, 07:03 PM   #8
Rewards Points: 1,022
The supply line isn't too small but the black pipe is way too large and just makes it look that way.
Old 02-21-2013, 07:04 PM   #9
Rewards Points: 582
Attachment 66115
Attachment 66118
dirt leg is not installed like that...tee is to be vertical....should have shut off within 3' of appaliance...flex connector has to be stainless steel and a min of 1/2id in size..ben sr
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
djlandkpl (02-21-2013), joecaption (02-21-2013)
Old 02-21-2013, 07:21 PM   #10
water heater
The shut off is near the back close to the wall and its been there for over 30 yrs..
Old 02-21-2013, 07:22 PM   #11
water heater
The T I will correct..
Old 02-21-2013, 07:25 PM   #12
water heater
Ben's
I do appreciate your advise.. and will correct.. my shut off is within 3' near the back
The Following User Says Thank You to GRed For This Useful Post:
ben's plumbing (02-22-2013)
Old 02-21-2013, 08:07 PM   #13
I just can't believe some of the codes of which supposedly intelligent people think. Put the shut off valve within 3 ft. of the appliance that may be on fire and could even be confined within a closet. So with that in mind maybe we should put the fire extinguisher in the cabinet above the cook top. DUH
Oh, BTW, the two connections of the drip leg to the T are running and bull headed. In this instance running is correct and bull headed is not correct.
Old 02-21-2013, 08:38 PM   #14
Master Plumber
Javiles's Avatar
Rewards Points: 994
First of all there is no such thing as grandfathered in, that only applies the the original installation on the original code. if i go into a home to do an inspection on a lets say new washing machine hook up and i walk by the water heater and its the original unit that was installed under that dates code, i cant make you make changes to it, now if you replace the heater you must now bring it up to the current code. no grandfather clause what so ever. what the guys here are telling you about that safety line is correct, i happen to do privet inspections and i am a licensed inspector, here's the reasoning for the new P&T code. years ago the safety line was piped in 3/8 OD flexible to the out side of the building, over the years it was determined that the line was too small and would clog easily, layer of paint, wasp would pack them with mud and lay eggs, etc, so they brought up the line size to 3/4 piped to the exterior of the building that was better but guess what lines still kept getting clogged and when p&t valve needed to fire it could not because of obstructions in the line, again for multiple seasons. and also if it did fire and and did not shut off well we had wasted water for who knows how long. so the code changed again, pipe it to the floor or if you want to pipe it to the outside it needs to have an air gap in a visible location in a downward position. what this does if the valve fires and the line is clogged it will over flow in the air gap. and the homeowner will be able to see it.
what you have done is Create a possibility for harm lets say the line over the years clog's out side for whatever reason if that valve blows at maximum capacity and someone is standing next to the heater your now forcing hot water through a 3/4 opening reducing it to 3/8 what do you think will happen.
its so simple and easy just pipe it down 6 inches above the floor. if your not going to take the advise of all professionals on this site why bother asking. this site has a great bunch of guys giving very good advise.
The Following User Says Thank You to Javiles For This Useful Post:
djlandkpl (02-22-2013)
Old 02-21-2013, 09:20 PM   #15
Water Heater
Javiles
Yes I do understand what your saying and will make the corrections.
I have tested that line and it is clear. for all practical purposes. however,, I will put in a new leg for the T&P and have it 6" above the floor..however I was doing what another plumber indicated as well.. and as far as the gas line leg..I need to turn that horizontal.. then I should be good.
I do appreciate everyones help.. Im just giving my side of this what I was advised as well.. I do understand that is its not opened and its orginal then its still within its own code...
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
