Update Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-15-2008, 03:27 PM   #1
Don't know it all, yet!
Update toilet
I want to replace an original 30 year old toilet with a new one. My original rough-in seems to be 14 inches. At least as measured from the bolt to the drywall. Most new ones seem to be 12 inches. I presume that is due to the smaller water tank.
Will it look odd with the two inch difference or should I special order one with the 14 inch clearance?
Am I measuring this correctly?
This is just a little out of what I am used to doing, plumbing-wise. No problem with taking one out to replace the wax ring, etc.
Thanks to all in advance.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 08-15-2008, 04:19 PM   #2
47_47's Avatar
Rewards Points: 44
The standard size for a toilet is 12". 10" and 14" are optional sizes. 14" is from the finished wall to the center of the closet flange / bolts.
A 2" gap would look terrible. I would replace your current one with a 14". The only other option would be to move the flange 2" closer to the wall, if you are doing a major remodel.
47_47 is offline   Reply With Quote
Old 08-15-2008, 08:16 PM   #3
That's what I thought but thought I would get a "second opinion."
Thanks,
Richard
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 04:43 PM
Need opinion - Need help - I believe my toilet was not installed properly rdlegacy Plumbing 9 05-06-2008 06:03 PM
why one toilet backs up and other does not Richmarti12 Plumbing 2 03-16-2008 03:22 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
