Old 10-23-2012, 08:45 PM   #1
Up-Flush Toilets
The only way for me to place a toilet in the basement, without breaking up the basement floor and incurring great costs, is the option of an Up-flush toilet.
I have heard good and bad about these toilets. Does anybody one of these and if so, have they incurred many problems? If so, what? Is there any brands that they would recommend? Is there anything I should question before getting one installed? Are there common problems with these type sof toilets?
Any helpful advice or opinions would be appreciated.
Slomarmoreno is offline   Reply With Quote
Old 10-23-2012, 09:54 PM   #2
Up-Flush Toilets
i have had good luck with liberty
http://www.libertypumps.com/Products...p=102&s=0&c=21
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 10-23-2012, 09:55 PM   #3
Up-Flush Toilets
Code says that you must use a gravity drain unless it is impossible. Since you are able to get to a gravity drain by breaking up the concrete, you have no choice and can not use an up flush toilet.
cube17576 is offline   Reply With Quote
Old 10-23-2012, 09:55 PM   #4
Up-Flush Toilets
what code is that
Old 10-23-2012, 10:07 PM   #5
A "Handy Husband"
rjniles's Avatar
Up-Flush Toilets
I have installed a Saniflo and it worked well.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 10-23-2012, 10:36 PM   #6
Up-Flush Toilets
Not only would I need to break up the concrete, bt I would also need to excavate the whole up to the street since the sewer line is about 4 feet up from basement floor.
Old 10-24-2012, 07:35 AM   #7
Up-Flush Toilets
I don't know what code cube17576 is under, but I've never heard of his interpretation. I used to own a home where the sewer line was hung on the basement wall like yours. My research at the time indicated Saniflo was one of the better brands. No personal experience though - sold the house before ever installing one.
Toilets On Same Wall Flush One And Level In Other Goes Down SJS947 Plumbing 2 09-14-2012 10:37 PM
Two toilets slow flush / two are fine? zrg345 Plumbing 8 03-06-2012 10:48 PM
toilets struggling to flush in new home Jfras419 Plumbing 9 08-06-2011 08:20 AM
Toilets don't flush efficiently rojeho Plumbing 5 10-06-2010 03:08 PM
Low flush toilets ? fixnbreak Plumbing 5 01-08-2010 03:49 PM
