Up Flush Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2013, 05:11 PM   #1
How far can an up flush toilet be located from the main drain. There will also be a shower and sink that will be hooked up to the main holding tank. My ideal location is about 25-30 feet away from the main drain. It will be hooked up to this drain that travels the length of the house (30-40 feet) and then turns 90 degrees where it travels about 10 feet before it exits the house into the septic tank. Any ideas. The alternative location is much closer to the main drain and septic but it is definitely not the best location in the basement... Any ideas are appreciated!
bestways is offline   Reply With Quote
Old 01-31-2013, 08:09 PM   #2
Do you mean your going to pipe in a bathroom into an ejector pump? If so the vertical height is what matters the horizontal run as long as it is pitching the proper pitch becomes gravity drain I believe the pumps usually will pump up twelve ft' if your higher than that doubtful you need a bigger pump
joes plumbing is offline   Reply With Quote
The Following User Says Thank You to joes plumbing For This Useful Post:
oh'mike (01-31-2013)
Old 01-31-2013, 09:08 PM   #3
Rewards Points: 636
all macerating pumps i have used require you to have vertical lift before horizontal drain
http://www.libertypumps.com/Products...p=102&s=0&c=21
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is online now   Reply With Quote
Old 02-05-2013, 07:33 AM   #4
It will have to be pumped up 8'...
Old 02-06-2013, 01:41 PM   #5
Amateuralex's Avatar
Rewards Points: 270
It depends on which one you get. I've been researching this and came across these guys, check out the chart, it shows how far vertically and horizontally they can go: http://www.upflushtoilet.com/collect...asement-toilet
Amateuralex is offline   Reply With Quote
Old 02-06-2013, 03:44 PM   #6
GBrackins's Avatar
Rewards Points: 2,108
make sure to use an effluent/ejector pump and not a grinder/macerating pump since you are on a septic system. Grinding up solids and sending them to your septic can cause some nasty stuff to happen, which could cause an early failure of your system.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old eljer toilet with flush ball (no flapper) leaks cbrc5eric Plumbing 18 04-24-2014 02:51 PM
Toilet Won't Flush schraggyj Plumbing 16 07-23-2011 04:22 AM
Gerber Pressure Toilet does flush all the way jimrens Plumbing 0 05-10-2011 10:10 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
