Up-drain Sink ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-14-2010, 06:21 PM   #1
The little lady wants a "convenience" sink in the basement. 2" washer drain is too high. Anyone know of a "pump-up" draining sink ?
Anyone know of an "up-draining" sink. Wifey wants a small "convenience" sink in the basement and the 2" washer drain is too high, but is nearby the desired sink site.
Thank you,
{2 threads/posts on same issue merged}
Moderator
skipperguy is offline   Reply With Quote
Old 04-14-2010, 07:04 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
where does the washer drain run too? Generally speaking, you aren't going to get water to run uphill without a pump so, does the washer drain into a sump with a pump?
Old 04-14-2010, 07:10 PM   #3
sounds like with some engineering you could use an hvac pump to washer drain
The older I get the better I was
Old 04-14-2010, 09:28 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
They make some self contained units that can fit into a moderately sized vanity cabinet. We've put in a couple of them, but I can't remember what they are called. They're effluent only pumps.
Realistically, however, adding a pump will complicate the system. Does she want the sink on the same wall as the washer? If so, it should be easy enough to tap a drain off below the washer's p-trap, run it horizontally and revent it into the washing machine vent.
Journeyman Plumber
Tags
basement , sink , updrain
Reversing P-trap in bathroom sink drain? DK75 Plumbing 3 03-02-2010 02:30 PM
adding new sink / faucet / drain assembly... and I'm clueless :-( diy'er on LI Plumbing 4 11-13-2009 06:36 PM
Sink Drain Stopper Won't Pop Up erclark Plumbing 7 07-11-2009 08:31 AM
pedestal sink drain stopper not working gernith Plumbing 7 04-18-2008 10:17 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 10:11 PM
