-   -   Up-drain sink ? (http://www.diychatroom.com/f7/up-drain-sink-69051/)
skipperguy 04-14-2010 05:21 PM
The little lady wants a "convenience" sink in the basement. 2" washer drain is too high. Anyone know of a "pump-up" draining sink ?
Anyone know of an "up-draining" sink. Wifey wants a small "convenience" sink in the basement and the 2" washer drain is too high, but is nearby the desired sink site.
Thank you,
{2 threads/posts on same issue merged}
Moderator
nap 04-14-2010 06:04 PM
where does the washer drain run too? Generally speaking, you aren't going to get water to run uphill without a pump so, does the washer drain into a sump with a pump?
tpolk 04-14-2010 06:10 PM
sounds like with some engineering you could use an hvac pump to washer drain
Alan 04-14-2010 08:28 PM
They make some self contained units that can fit into a moderately sized vanity cabinet. We've put in a couple of them, but I can't remember what they are called. They're effluent only pumps.
Realistically, however, adding a pump will complicate the system. Does she want the sink on the same wall as the washer? If so, it should be easy enough to tap a drain off below the washer's p-trap, run it horizontally and revent it into the washing machine vent.
