Unusual Toilet- Broken Flush Lever - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-07-2009, 03:21 PM   #1
sweaty
Rewards Points: 276
My house, built in 1976, has an American Standard Vent Away toilet. I was trying to attach the flapper actuator chain to the flush lever. About a half inch of the end of the lever broke off. It's thin plastic. Here is a diagram of the parts:
http://www.lockeplumbing.com/americanstandard/2003v.pdf
I'd rather not buy entire new part assemblies for this. Just a fill valve cost $200.00. Can I wrap wire around the remaining flush lever or attach it to the actuator chain somehow?
I need to keep the original toilet. It's brown, which matches the bidet, tub, and towel hangers.
sweaty is offline   Reply With Quote
Old 07-07-2009, 04:28 PM   #2
The trip lever assembly is only $37. But you might try contacting American Standard http://www.americanstandard-us.com/contactUs.aspx
hayewe farm is offline   Reply With Quote
Old 07-08-2009, 04:52 PM   #3
biggles's Avatar
take a safty pin open it up hold it with a needlenose plyers and heat the sharp end over the stove flame or lighter.heat it up and stick it thru the end of the remaining handle bar...let it cool and close it then hookthe flapper chain to it....paper clip will do it also or just drill a small hole and slip half a paper clip into it....and hook the end for the chain.
Old 07-09-2009, 09:22 AM   #4
sweaty
Rewards Points: 276
I fixed it. I drilled a hole through the remaining lever, linked a couple safety pins to it, used copper wire to fasten the pins to the chain. Just slightly better than duct tape and chewing gum. Should keep the wife off my back, at least for a few minutes.
Old 07-09-2009, 05:02 PM   #5
biggles's Avatar
keep your eyes open when traveling the neighborhood might see an old bowl going out...and clip the handle assembly with the arm....try to smile as people check you out on that one
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Dual Flush Toilet 2031pratt Plumbing 6 03-11-2009 11:55 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
weird pipe noise after toilet flush bourbonboy Plumbing 1 11-30-2007 04:18 PM
New Toilet Does Not Flush klugej Plumbing 3 04-30-2007 10:51 AM
