Unused Water Well - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-23-2009, 05:56 PM   #1
Unused water well
I bought the house in 1995 and the homeowner couldn't get the water well to pass a safety inspection. He put in city water and since then the well has not been used. There is a nice building over the top of it, very well insulated, Not an eyesore at all.
Every spring, I might get a few weeks with a little bit of water coming out, but with the heavy rains in Arkansas, it's still flowing alot. I would say 2 to 3 gpm give or take.
Someone told me once that if you cement a well, it takes value from your house, however, having a non-wanted lake behind my house can't be good either. My entire back yard is wet and spongy.
I'm guessing I'll be calling a well specialist, but wondering if you guys have any ideas as far as abandoning the well, or make any necessary repairs to keep it. My wife and I want to sell the house in 2-3 years.
Thermographer is offline   Reply With Quote
Old 05-23-2009, 06:03 PM   #2
Ground water is coming up thru the well?
Old 05-23-2009, 06:31 PM   #3
It always happens in the Spring but just for a few weeks. I guess you can call it a part-time artesian well.
This year we've had a lot of rain, with more on the way.
Old 05-23-2009, 06:36 PM   #4
GC/Master Plumber/Mech
Rewards Points: 560
Do you know how deep it is? I'm guessing not very deep 30-40 since when it rains water comes up. Water table not very deep.
If you do then you can fill it with gravel up to about 10 ft from the top. Add bentonite up to about 3 ft from the top and then top off with cement
Old 05-23-2009, 06:53 PM   #5
Thanks for the reply.
No idea how deep, but i could find out. I do know there is no submersible pump at the bottom, both pumps were in the well house.
I working now but can answer that next Wednesday.
Old 05-23-2009, 06:55 PM   #6
Check with your local health department of filling requirements. In some areas it is very strict. If it is an artesian be warned that capping may not work.
hayewe farm is offline   Reply With Quote
Old 05-24-2009, 01:19 AM   #7
Rewards Points: 562
here they have a program to have a pro well driller abandon and cap it properly. Doesnt cost anything I know of
4just1don is offline   Reply With Quote
Old 05-24-2009, 07:46 AM   #8
Every area has it's own rules about capping wells. In Florida, a certain type cement was required (twice the price of regular cement) and the work done by a licensed well driller. Strange part was that my old well was 110 foot deep and the estimate for the amount of cement was 2/3 more than it actually took to do the job.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 05-24-2009, 11:18 AM   #9
Water quality'n pump guy
Another possible solution is to run a pipe to take the water somewhere instead of letting it run on the yard to soak into a septic tank drain field and ruin it.
Capping/plugging a well can cause serious blow out problems meaning, it could push the casing up out of the ground, or the water can start coming up around the casing washing a big hole in the yard, and the water in the yard will still be a problem.
Gary Slusser is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Why do water heaters have two elements? gp_wa Plumbing 21 02-09-2012 01:56 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
