Unused Underground Soil Pipe. - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-06-2010, 11:19 PM   #1
Unused underground soil pipe.
I am relocating a water closet in my basement and will abandon the existing 3" drain. Is it "plumbing" legal to cap the unused soil line under a basement floor?
hebes99 is offline   Reply With Quote
Old 04-07-2010, 10:25 AM   #2
Yes, but make sure you cap it securely so sewer gas or waste will not leak into the house. There is no trap on the pipe in the floor.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
The Following User Says Thank You to majakdragon For This Useful Post:
hebes99 (04-07-2010)
Old 04-07-2010, 10:42 AM   #3
Thanks! I was unsure since I have read in some plumbing codes that unused soil lines should be "avoided".
Old 04-07-2010, 10:57 AM   #4
Since the pipe is in the basement, it is likely connected to your main sewer line. Capping it is the only way to discontinue the usage and not disturb the rest of the drainage system.
Old 04-07-2010, 11:22 AM   #5
It is a somewhat strange setup. The line connecting the old toilet is a horizontal branch off the main sewer line (all underground). So capping it will not disturb the remaining house plumbing. I was worried about what an inspector might say as interpreted by the plumbing code.
Old 04-07-2010, 11:27 AM   #6
I see no problem with an inspector. You could even cover the cap with concrete to be able to install flooring or just to prevent a tripping hazard. You will not be interfering with the main drain lines functioning.
Old 04-07-2010, 11:32 AM   #7
Yeah all you need to do is cap it off to where it is airtight! You don't want sewer gases flowing into your house
lanemiller is offline   Reply With Quote
Soil waste pipe through pitched roof DIYifposs Roofing/Siding 1 11-21-2009 02:34 AM
Cover Up Soil Pipe in Garage? mark2741 Plumbing 4 10-20-2009 09:29 PM
Leak in Soil Pipe mark2741 Plumbing 6 08-30-2009 08:50 AM
getting rid of unused pipe altadata Plumbing 5 02-05-2009 06:05 PM
Underground orangeburgh pipe leading to storm sewer is blocked somewhere flashme18 Plumbing 10 07-21-2008 11:48 PM
