Unsticking Copper Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-11-2013, 11:56 AM   #1
I am trying to create a pressure balancing loop for a 4 nozzle ceiling shower valve.
Everytime I dry-fit components together they get stuck and I cannot get them apart without damaging the components.
Any trick's for dry-fitting without needing to use wrenches and pliers excessively to pull them apart again?
Thanks.
hotelinorbit is offline   Reply With Quote
Old 10-11-2013, 12:07 PM   #2
Rewards Points: 13,748
Deburr the pipe.
If you complete the closed loop you may be creating a suction when you try and pull them apart.
jmon (10-11-2013)
Old 10-11-2013, 12:07 PM   #3
Rewards Points: 282
You can put a little flux on it, or measure more accurately, prep pipe for soldering, and be done with it.
jmon is offline   Reply With Quote
Old 10-12-2013, 08:46 AM   #4
Thanks guys ... I had to have the measurements pretty precise because of the nozzle locations. I got a better wire brush, liberally applied flux, through out the old failed attempts, and was able to fit things "one time" without having to pull them apart.
It was a little challenge applying the last piece to the loop, and my mallet helped out significantly.
Old 10-12-2013, 08:51 AM   #5
Rewards Points: 282
Great. Glad everything worked out for you.
Old 10-12-2013, 10:25 AM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 682
Sounds like your cutter wheel is dull and forming a ridge on the pipe
The Following User Says Thank You to TheEplumber For This Useful Post:
oh'mike (10-13-2013)
Old 10-12-2013, 12:18 PM   #7
Mr. E. Thanks! I have one of those Milwaukee Electric Pipe Cutters and upon very close inspection I can see a very fine ridge on the pipe end. I have never replaced the cutting wheel.
I'm going to try a new cutting wheel because I'm continuing to have problems elsewhere.
Old 10-12-2013, 12:46 PM   #8
Plumber
Rewards Points: 682
You can knock the ridge down with a small file
Sent from my iPhone using DIY Forum. Watch out for spell check
Old 10-12-2013, 08:53 PM   #9
Lord of Slums
Rewards Points: 1,974
You can avoid home depot fittings
mj12 is offline   Reply With Quote
Old 10-13-2013, 08:51 AM   #10
Dull cutting wheel was definitively the problem. When I tried my spare hand cutter dry fitting no longer was as tremendously difficult.
The Following 3 Users Say Thank You to hotelinorbit For This Useful Post:
jmon (10-13-2013), oh'mike (10-13-2013), TheEplumber (10-13-2013)
Connecting PVC Sprinkler Pipe to Copper House Main Line fritzycat1 Plumbing 6 05-15-2013 03:25 PM
How to Estimate Water Flow Rate in Copper Pipe arskiracer Plumbing 12 04-15-2013 08:50 PM
Soldering copper pipe in tight location- Help Needed Pics included amodoko Plumbing 20 08-11-2012 04:14 PM
where do I set the black o- ring on the tub spout? or the threaded copper pipe? radioflyer77 Plumbing 1 07-05-2012 09:23 PM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 09:49 PM
