-   -   Unsticking Copper Pipe (http://www.diychatroom.com/f7/unsticking-copper-pipe-188422/)
hotelinorbit 10-11-2013 11:56 AM
I am trying to create a pressure balancing loop for a 4 nozzle ceiling shower valve.
Everytime I dry-fit components together they get stuck and I cannot get them apart without damaging the components.
Any trick's for dry-fitting without needing to use wrenches and pliers excessively to pull them apart again?
Thanks.
joecaption 10-11-2013 12:07 PM
Deburr the pipe.
If you complete the closed loop you may be creating a suction when you try and pull them apart.
jmon 10-11-2013 12:07 PM
You can put a little flux on it, or measure more accurately, prep pipe for soldering, and be done with it.
hotelinorbit 10-12-2013 08:46 AM
Thanks guys ... I had to have the measurements pretty precise because of the nozzle locations. I got a better wire brush, liberally applied flux, through out the old failed attempts, and was able to fit things "one time" without having to pull them apart.
It was a little challenge applying the last piece to the loop, and my mallet helped out significantly.
jmon 10-12-2013 08:51 AM
Great. Glad everything worked out for you.
TheEplumber 10-12-2013 10:25 AM
199 Attachment(s)
Sounds like your cutter wheel is dull and forming a ridge on the pipe
hotelinorbit 10-12-2013 12:18 PM
Mr. E. Thanks! I have one of those Milwaukee Electric Pipe Cutters and upon very close inspection I can see a very fine ridge on the pipe end. I have never replaced the cutting wheel.
I'm going to try a new cutting wheel because I'm continuing to have problems elsewhere.
TheEplumber 10-12-2013 12:46 PM
199 Attachment(s)
You can knock the ridge down with a small file
Sent from my iPhone using DIY Forum. Watch out for spell check
mj12 10-12-2013 08:53 PM
You can avoid home depot fittings
hotelinorbit 10-13-2013 08:51 AM
Dull cutting wheel was definitively the problem. When I tried my spare hand cutter dry fitting no longer was as tremendously difficult.
